Windows 7: General Question about laptop battery charging AND 0% battery
28 May 2015   #1
LuisBelmontShow
I am becoming more and more concerned about my laptop's battery each and every passing day. When I check the bottom right of my computer screen to check if my computer battery is completely charged, it says "0% available (plugged in, not charging)". I have had to buy two new batteries because of the same thing and they also read "0% available (plugged in, not charging)". When I unplug my laptop from the power source, it turns off automatically. I cannot even bother calling Dell to check this issue for me because I bought this computer off the street for $35.
My question in general is how do I get this problem fixed and how do I keep an eye on how my laptop computer charges correctly (or not)???
General Question about laptop battery charging AND 0% battery-20150528_162543-1-.jpg
28 May 2015   #2
GokAy
Some reading and testing for you
Why is my Laptop battery not charging? – Drivers.com updates
Laptop Battery Not Charging | PCWorld
https://www.youtube.com/watch?v=XcDvp2A7Fss
The common method is:
- Create a System restore point
- Uninstall (Under the Batteries category in Device Manager) the Microsoft ACPI Compliant Control Method Battery.
- WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
- click Scan for hardware changes
dell laptop battery not charging
i replaced the old battery with the new one as the old one wasnt being charged the problem was that old battery message "" plugged in, not charging" the problem didnt go away with the new battery
Hardware & Devices
General Battery Question
I have purchased a replacement battery for my HP G42 laptop that is not an original HP mainly because its a lot less cheaper. So my question is would this battery have any effect on the other hardware components of my laptop? Btw, I noticed that sometimes it randomly shuts down as if you have...
Hardware & Devices
Battery Meter shows CMOS battery not charging
I have just replaced my CMOS/BIOS battery today, as , I have faced some critical problem regarding regular BIOS date/time reset after system shutdown. But I want to know how do i recognize, that my new batter is totally ok or functional. Battery Meter gadget shows that "battery Not charging"...
Hardware & Devices
Charging laptop BATTERY!
I bought a HP pavilion dv6 laptop! I just want to know is it bad if I leave my laptop charger connected all day even if its fully charged? :sarc:
Hardware & Devices
Laptop Battery - Plugged in, not charging.
As per the thread title, the battery is recognised as being present, but is not charging, and when the power is disconnected, will not run on battery power. I have come to the conclusion that it is most likely a hardware issue, see below. Comptuer is the one in my 'System Specs', just on 2...
Hardware & Devices
Laptop Battery not charging past x %
Hey guys, I have an Acer Aspire 5741-6073, and it would not charge past 40%, even with the power cord plugged in for several hours. I reported the issue to acer, they asked me to drain the battery then press and hold the power button for 30 seconds to discharge any remaining charge. Then while...
Hardware & Devices
