Laptop suddenly starts running slow after low battery
I was playing League of Legends one day, when my fps started to drop.
Over time, it got worse and worse, and I noticed my battery was low. Turned out, the charger fell out while I was moving my computer. So I plugged the charger in, fixed some problems with "plugged in, not charging", and continued to play. Battery was at 40%, and my fps in game still hovered about 2-20(I consider this bad, normally running at 144 fps), and decided to reboot my computer. After rebooting, I tested out my fps again, and it was at 2-12 fps this time. I finally decided to check my cpu usage, and it was hovering around 100% the whole time. I did a CCleaner registry clean, a MalwareBytes scan and clean, a CCleaner space clear, and the problem is still not fixed. Normally I am able to run League as well as many other programs at the same time without lag,I don't know why my computer suddenly started acting so slow, maybe it was because of the battery being low. Still, last time my battery was low my computer was just as fast, so I have no clue what happened. Also, its not just League that lags, Youtube and Twitch have spikes very frequently aswell. My computer also is slow, my browser freezes alot too.
You can find my specs in the images below (I have windows 7, I just decided to use an XP look to make my computer run a little faster)
