Windows 7: Power Options Help Advanced Settings Options
13 Jun 2015   #1
legolego235
I have three normal settings, but there is an odd one that stands out and does not use english characters. Does anybody know how to solve this?
13 Jun 2015   #2
derekimo
Do you have a game booster installed?
13 Jun 2015   #3
legolego235
I don't have one running but it might be game booster from the advanced system cleaning program
13 Jun 2015   #4
derekimo
Yeah, who knows what those programs install.
There was a mention of it being related to Razer too if you have one of their products.
Folder Options Advanced Settings Missing
Hi, I'm really in need of help, I've tried everything to correct this issue but nothing has worked. I'm in need of showing my hidden files, but when I go to the folder options, there is nothing under Advanced Settings. The box is there and everything, but it's completely blank. I googled...
General Discussion
How to set Advanced options in Power Options (64 bit Ultimate)
I have an older Belkin F6C1500-TW-RK UPS and the mfg has not offered software management for the Win 7 64bit OS. I want to let Win 7 manage the battery and shutdown. I set the High Performance under Power Options to turn off display and put the computer to sleep after 3 minutes as a test. I yanked...
Performance & Maintenance
Damage to Power Settings / Options Win 7 Home Premium x64 ?
Gang I'm doing a repair on a dell Inspiron notebook, shipped with Win7 HP x64 preinstalled. Its about a year old roughly, and was terribly treated by its owner :( So it is taking me awhile to kill trojans, pull malicious code, etc. One question I have since I generally know Ultimate better...
BSOD Help and Support
Advanced Power Options Shortcut - Create
How to Create an "Advanced Power Options" Shortcut in Windows 7 and Windows 8 This tutorial will show you how to create or download a Advanced Power Options shortcut in Windows 7 and Windows 8. This shortcut will open to the advanced settings of your currently selected power plan by default....
Tutorials
Power Options/Power plan settings?
From Windows 98SE/2000/XP SP3 I always set my power settings as always on/never shut down (hard drive always on) with the exception of turn off display after 10 mins. Both my PCs are on for about 16-20 hrs each day and I always shut them down manually every night. Now in Windows 7, I created a...
