Windows 7: Power issue help Need
27 Aug 2015   #1
hashir
window 7 64 bits
I had diagnosed my pc power test found thesese error and warning any way to fix these????
Errors
Platform Power Management Capabilities:PCI Express Active-State Power Management (ASPM) Disabled
PCI Express Active-State Power Management (ASPM) has been disabled due to a known incompatibility with the hardware in this computer.
Warnings
Platform Timer Resolution:Platform Timer Resolution
The default platform timer resolution is 15.6ms (15625000ns) and should be used whenever the system is idle. If the timer resolution is increased, processor power management technologies may not be effective. The timer resolution may be increased due to multimedia playback or graphical animations.
Current Timer Resolution (100ns units) 10000
Maximum Timer Period (100ns units) 156001
Platform Timer Resolution:Outstanding Timer Request
A program or service has requested a timer resolution smaller than the platform maximum timer resolution.
Requested Period 10000
Requesting Process ID 3184
Requesting Process Path \Device\HarddiskVolume2\Program Files (x86)\Google\Chrome\Application\chrome.exe
Power Policy:802.11 Radio Power Policy is Maximum Performance (Plugged In)
The current power policy for 802.11-compatible wireless network adapters is not configured to use low-power modes.
CPU Utilization:Analysis Error
Analysis was partially unsuccessful. Some results are available, but they may be incomplete.
27 Aug 2015   #2
GokAy
I believe these are the result of some default settings, and you shouldn't worry about it. At least about PCI-e Active-State Power Management and Wireless (802.11 radio Power ...). These can be found in Advanced Settings of Power Plans (Power Options).
28 Aug 2015   #3
hashir
window 7 64 bits
how to fix it?
28 Aug 2015   #4
GokAy
I am not even sure if there is anything to fix. How did you get those results you wrote in post #1? Some command or program?
28 Aug 2015   #5
hashir
window 7 64 bits
yeah by diagnosing battery life its available in this forum !
here is the link
Power Efficiency Diagnostics Report[2]=Power%20Management
28 Aug 2015   #6
GokAy
Your Errors and Warnings seem normal, no action needed if you ask me. I have run the command just to see and I get even more Errors and Warnings (most due to how I set max performance power plan) including the ones you are getting (but for a different app).
Read the other 2 pages of the tutorial (especially last page) for someone else's report, has more errors/warnings and it was said to be alright.
Random Power Down Issue - 'Event 41, Kernel-Power'
Hi Guys, I'm currently suffering from a random power shutdown issue. The PC boots up correctly and is totally useable and in working order. However after different varied amounts of time. 20mins - 5 hours on occasion. The PC will just randomly power down as if the power cable has been...
General Discussion
Power Issue
Hey I have an hp computer with windows 7, and my power options are set to never turn off display and never put the computer to sleep. But after one or 2 minutes it will go back to the login screen, I'll still be logged in but it goes back to the login screen. How do i fix this?
General Discussion
PCI/E Power Issue
Here's an interesting one that I think only Microsoft can fix (and I hope they do) I have my USB 3 external drive connected to a 2 port USB PCI-E card. Every time I "wake" the PC from sleep, I hear the sound of a USB device being disconnected and reconnected followed by the Auto Play options. This...
Hardware & Devices
power issue
Hello This is my Current System:- Windows 7 Home Premium x64 (fully updated) Windows XP Profesional x86 (fully updated to SP3) Zalman GS1200 Pro Tower Case Fractal Design Newton R2 1000W Modular PSU Asus Crosshair IV Formula AMD Phenom II 1100T x6
Hardware & Devices
Power Off issue
Hi there. Trying to figure out a new motherboard ASUS M4A78LT-M with a 3-core Athlon CPU, running windows 7 64bit. I had never had this problem before on other PCs. When I press the power off button on the front, it automatically restarts the PC after a few seconds. The only way to keep it 'off' is...
Hardware & Devices
Power Supply Issue
Wasn't sure where to post this (slightly off topic but I figured someone on here would be able to shed some light on this). I have an HP DV7-4285DX laptop, the machine runs Windows 7 Home Premium and is performing quite well after a good weekend of "De-OEM'ing" (uninstalling the crap it came...
Performance & Maintenance
