Windows 7: System running slow after many AV clean ups
27 May 2016   #1
qmck1999
Hello,
Running ACER win 7 Home Prem and a few weeks ago, just started running slow. I have Avast AV running, removed some programs, and ran several virus programs (tdsskiller-kaspersky; rkill-bleepingcomputer; malwarebytes-malwaretips; roguekiller-bleepingcomputer; AdwCleaner-toolslib.net; JRT-thisisudax.org; and esetsmartinstaller_enu-eset.com). The AV programs came up with minimal issues. In looking at the Services, I see svchost.exe taking about 60%.
Any suggestions?
Thank you
27 May 2016   #2
Layback Bear
Windows 7 Pro. 64/SP-1
It would be helpful if we new your system specs.
This tutorial by Brink is helpful for filling in your system specs.
System Info - See Your System Specs
27 May 2016   #3
qmck1999
I uploaded the sys info, but am not seeing how to get it into this post.
29 May 2016   #4
Alejandro85
Quote   Quote: Originally Posted by qmck1999 View Post
Once you update it in your settings, it becomes available at every of your posts (past or future) though the link "My System Specs" on the lower left corner of each post.
29 May 2016   #5
qmck1999
Go it, thanks. I am seeing the info is there. So, now onto a solution. Any suggestions?
31 May 2016   #6
Layback Bear
As per qmck1999 P.M.
Note: I'm not a security expert.
These are things I would do if it was my computer.
The list of programs you run looking for infection are very good programs.
I do have a question.
In your post you state this.
Do you still have logs showing what you are calling minimal issues or do you remember what the issues were?
It could help if we knew what the issues were and how they were handled.
If I had this computer to repair I would remove all those infection scan programs because you are done with them at this time.
Then I would remove Avast using it's online removal instructions.
Then after a fresh boot I would run TFC and then reboot again.
Get TFC from here.
TFC Download
Then I would download and install Malwarebytes Anti Malware and MSE (update both).
Microsoft Security Essentials - Microsoft Windows.
Malwarebytes comes Free, Trial or Premium. Choose one from the Malwarebytes site or Bleeping Computer site.
***What browser are you using??
***Do you have Ccleaner installed??
If you decide to follow my instructions let us know the results and we will go from that point on.
31 May 2016   #7
ThrashZone
Win-7-Pro64bit 7-H-Prem-64bit
Hi and welcome to SevenForums,
svchost.exe has been a fairly popular cpu eater lately
Mostly because of the windows update system
If you switch to Never check for updates and restart it may return to normal.
You can try option 3 here and wait it out,
Windows Update - Reset
01 Jun 2016   #8
qmck1999
Quote   Quote: Originally Posted by Layback Bear View Post
--I do not
Browser - Mostly Chrome, sometime FF or IE
Do not have Ccleaner.
I am also running Ultimateoutsider's GWX Control Panel to stop WIN 10 updates.
Have followed Layback's protocol above and just finished running MSE, Quick scan, which took 18 hrs. No threats found. Am now running full scan.
So.... Any suggestions?
01 Jun 2016   #9
indianacarnie
You could always do a repair install. It will save all your data/programs and just repair anything wrong with Windows. Many cleanings multiply your chances of "cleaning" a wrong thing or two. While all your listed programs are reputable ..... well, you just never know. We have many excellent tutorials here at the forums, written by some very talented people, here's one on how to do a repair install if you haven't before : Repair Install
03 Jun 2016   #10
Layback Bear
Because of this in your post #1
I recommend checking your Windows 7 Update settings.
If it is set to Auto Update your svchost could be high at times.
Chrome will also raise svchost because of the way it works.
Check and see how much svchost is being used by Chrome.
Could you post from your computer these two pictures?
Notice that in Services that the box in the lower left Hide Microsoft Services is checked.
Win 7 extremly slow, even after clean install. CPU running low, RAM ok
Hey guys, I'm new here, and I really need yours help. Two months ago my computer started crashing on startup, BSOD, and after first crash, I boot it up again, and than works normally, like nothing happend. But I wanted to fix that, and I shut down all services on startup, that aren't related to...
Performance & Maintenance
Windows Update keeps running and running for hours...Clean Install SSD
Hello all... Befuddling problem as I am pretty tech savvy but for whatever reason I can not get windows update to quite "checking" for update: So far.... 1) Downloaded SURT, ran fulling with no reported errors 2) Ran SFC with no reported errors
Windows Updates & Activation
Dell Inspiron N4110 — AC Adapter Not Recognized, System Running Slow
My Dell INS-N4110 laptop has been around for roughly 5 years. It's no powerhouse but I wouldn't call it much of a slouch either. Just recently, it's started randomly getting slow; games would lag and even Chrome would run like it was being processed on a Win98. Pulling the power and taking out the...
System running very slow intermittently
Starting a few weeks ago, my system started suddenly running very slowly (e.g., taking 15 minutes to shutdown). But it's oddly intermittent—sometimes it seems to run almost normally, and sometimes (like this morning) it takes quite a long time to startup and when it does, Aero is suddenly...
Prefetch folder is deleted.system running extremely slow
i am running windows 7 ultimate 64bit edition.i have tuneup utilities 2012 installed.couple of days back it notified me that some other program deleted my prefetch folder and i may experience slow log on and boot process.from that day my computer is running extremely slow and booting and logging...
System running slow, freezing up
Hi, I have recently had some problems with my laptop. Error reading from hard disk when booting, did clean instal then user accounts gone etc. They all have been solved and after that it started to run slower and slower and frezing up constantly now. So: I can start windows in safe mode, it...
BSOD Help and Support
