HELP REQUIRED PLEASE!! WIN 7 64 bit system
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 11,840
    64-bit Windows 8.1 Pro
    Have you tried updating DirectX?
  2. Posts : 171
    Windows 7 64 bit
       #12
    Tried to zip the files using Winrar but have a message saying access is denied!
    Please bear with me as i am a total Novice with these things as am sure you can tell..
    I use my software but have never really touched on IT things before....
  3. Posts : 11,840
    goto c:/windows/minidump... right click on the .dmp file... select send to .. select compressed zip folder ... attach it to next post.. hope this helps..
  4. Posts : 171
    Windows 7 64 bit
       #14
    Hi, there are seven minidump files but constantly receive access denied when i try to compress them or even just one of them....
  5. Posts : 11,840
       #15
    Take ownership of the files then try... Take Ownership Shortcut
  6. Posts : 29
    The error during compression is most likely due to the fact that the location (c:\Windows ...) is not writable (UAC or Standard User).
    Copy the minidump to your desktop and then compress it.
  7. Posts : 171
    Windows 7 64 bit
       #17
    Installed take ownership and still nothing, wont allow access
    Minidump files copied to desktop but still denying access for compression
  8. Posts : 29
    Well that's odd .. may I suggest you use a location other than the C drive. Or use another zip utility.
  9. Posts : 171
    Windows 7 64 bit
       #19
    The entire system has behaved oddly from day one! lol
    I really need a break from this I think, have been working on it for 56 hours with only 3 hours sleep, i really would welcome any further suggestions, as i say there are seven minidump folders on there.... i also cant turn on windows defender, it says that i dont have the rights to???
    Is there somewhere i should set up and confirm my administrator rights???
  10. Posts : 171
    Windows 7 64 bit
       #20
    OK, did something with file sharing and it seems to have allowed me to compress, i will try and attach here
