Problem with Solid Edge
  1. cel
    Windows 7 :/
    When I install Solid Edge everything goes find but in the end Removing temporary files used just keeps loading... I ended setup process and Solid Edge works fine, but now if I try to install any other appliaction its says: Another install process is paused, and it then it gives me option to remove solid edge or close setup of new application. I have tried running in vista sp1 mode, as administrator, but still the same, so is there any way to somehow end the install.
    EDIT: Nevermind, I'm gona roll back to vista, too many problems.
  2. Posts : 1
    If you kill the process "PrinterInstaller.exe" the installation will continue and you will be able to use Solid Edge. The problem is that you can't install any MP on top of this installation.
  3. Posts : 1
    Problem installing Solid Edge in Win 7
    I experienced the same problem - tgtbe, what do you mean with "you can't install any MP on top of this installation". What is MP?
    mvassal
  4. Posts : 1
    windows 7
    Solid Edge problems in Windows 7
    i also face same problem please tell me best solutions
  5. Posts : 1
    windows 7
    SolidEdge probloem on Windows 7
    Same problem! I tried to kill the installation and restart my computer, but then SolidEdge was uninstalled automaticly.
  6. Posts : 1
    SOLID EDGE IN WIN 7:
    Right click on all Application file (.exe) in SolidEdge Folder, then choose the Tab Compatibility, Set: Win Vista or Previous Win, also choose Run as Administrator.
    It works well. You can see: a piece of cake!
  7. Posts : 1
    Windows 7 x64
    Thanks a lot.:)
    It solved the problem.
  8. Posts : 1
    windows 7
    Solid edge problem
    Dear,
    I can't Install solid edge in windows 7.
    Please can you give me a right solutin.
