Windows 7: Advanced System Optimizer, System Protector, Start up problem
06 Jul 2012   #1
unknown01
Windows 8 RTM Professional X64
Hello guys,
I have this program in my computer called "Advanced System Optimizer" and it has a program called "System Protector" and I just want to disable it forever or at least not to show at my system start up, every time I turn on my computer it comes up and it is really annoying. There is no option in "msconfig" but there is option in program's settings that I unchecked it but still it comes up at system start up.
And FYI: my advanced system optimizer is fully registered.
Any Would would be greatly appreciate it.
Thank you.
~0UnknowN1
06 Jul 2012   #2
DELLsampadc
windows 7 64bit
Hey unknown01,
I am Sampad from Dell Social Media and Communities team.
First go to system configuration utility ( Run ... type - Msconfig ) .
From services unclick ASO3DiskOptimizer .
And from under Start Up unclick System Optimizer.
Usually this is enough but they've made this program tricky ( kind of strange since the program is about making things run smoother and it has lot of useful tools in it ) .
Also download free program autoruns found f.exp. here Lataa Autoruns v11.32 (ilmainen ohjelma / freeware) - download.fi ) .
(THIS IS FREEWARE AND IT IS A RECOMMENDATION)
Start the program and choose Scheduled Tasks . From there unclick ASOService.job and now you can only use the program when you want to, not when the program decides to come around ...
Let me know if it worked or not.
Regards
Dell-Sampad C
Dell Social Media and Communities Professional
06 Jul 2012   #3
derekimo
I would just uninstall that, Windows 7 doesn't need any optimizing.
Those self proclaimed fix-all programs don't usually fix anything.
It's your call though, let us know how it goes.
07 Jul 2012   #4
unknown01
Thank you "DELLsampadc" it worked and it doesn't show up at system start up. Thank you.
~0UnknowN1
Advanced system optimizer 3 legit or scam?
I thought it was a scam but what is it in your opinion? Also I used and still have on my pc: CCleaner which is legit right?
Performance & Maintenance
What is a good, free "system optimizer" that noticeably works?
Hi I used to have Advanced System Care, but their latest free version removed some features. I am wondering if there are any similar programs for free that can optimize my system in a way that is actually noticeable (fast boot time, snappier response, etc.) I am running Windows 7 64 bit on a...
Software
Advanced System Care Pro.
I am using Advanced system care pro in my laptop for system optimization. I am using all of it`s properties and actions.... I want to know the opinion of this forum members regarding its usage on my laptop...:geek:
Software
System Restore Option Missing from Start Menu/Accessories/System Tools
On the subject of System Recovery For some reason, the option for System Restore disappeared from the Tools file of my Accessories Folder in the Start Menu. In order to recover, I Googled but after hours of searching could find NO answer which helped to recover the option even though a lot of...
Backup and Restore
hi ladies and gents does anyone know if advanced system care works on windows 7 64 bit with out any problems?
Software
Advanced System Settings
Hello I need some help on creating a Short Cut On desk top for " Advanced System Settings " :orb: Thanks Bob
General Discussion
