Technical problem using Word, Chrome and other S/W.
  1. Posts : 2
    Hello there,
    I woke up this morning and the computer was on low battery and I couldn't plug the charger in time for it to stay on charge. This meant the computer had a message"start in repair mode " or "start normally" I chose the former first and it took almost 2 hours and nothing happened, so I turned the computer off.
    When I turned the computer back on, I am unable to use any software as it keeps prompting me with some message with a dll. For .e. g I normally use Google chrome or Microsoft Word. For both it had these messages..
    Word- "Installing Microsoft Office Single Image 2010..., later WinWord.Exe System Error- The program cant start because MSVCR90.dll is missing from your computer. Try reinstalling the program to fix this problem "
    Google Chrome- The program can't start because COMCTL32.dll is missing from your computer. Try reinstalling the program to fix this problem.
    I have tried to restart my computer, restore my computer to an earlier point so far with no luck. Any suggestions would be welcome. Help!.
    Thanks!.
  2. Posts : 2,177
    Windows 8.1 Pro x64
    Hi, Welcome to SevenForums,
    This does sound like a strange issue, you could try following this guide - SFC /SCANNOW Command - System File Checker
    This will repair any system files.
    Regards,
    Jamie
  3. Posts : 2
    Thank you, I ll see what happens and let you know.
