Windows 7: onboard sound vs. Addon sound card
15 Sep 2010   #1
bassfisher6522
Windows 7 Ultimate 64 bit
What would be the advantages/disadvantages of onboard sound vs a sound card? With a sound add on card are there headers for front panels connections.? Would I see/hear a big difference in the sound?
15 Sep 2010   #2
fireberd
Windows 7, 64 bit Home SP1, Win 8.1.1 Pro 64 bit
It would depend on what you want from the audio or what applications you have for it. I have a home built using an Intel motherboard that has IDT (SigmaTel) HD audio on it. It's fine for most of the "listening" that I do However, I have a music program that uses MIDI and the default built in Windows/Microsoft GS Wavetable MIDI Synth is pretty bad. For that reason I have a SoundBlaster Xfi installed and SoundBlaster has on board hardware MIDI synths that are much better.
15 Sep 2010   #3
Lemur
Typically, you can get a higher-end device with a sound card. If you wanna have a surround sound-type experience, then you might consider a card:
Newegg.com - ASUS Xonar Essence ST 24-bit 192KHz PCI Interface Audio Card
If you are gonna put your audio through $15 speakers, then forget the card and use the onboard audio chip.
15 Sep 2010   #4
Barman58
Windows 8.1 Pro x64 x3 + Windows 10 Preview, Ubuntu
Depends on what you are looking for and as always what you are prepared to pay for it
To be realistic for most purposes the on-board chip's on today's systems are perfectly adequate for most peoples needs, if you are a serious audiophile or looking to use the pc for professional sound production, even DJing, that the flexibility and quality of add on external units are probably worth the extra cost and installation. In fact if you are a dj an extra card is virtually essential to allow off-line cueing etc.
15 Sep 2010   #5
stormy13
Microsoft MVP
Win 7 Ultimate x64
Another age old debate. Here is a thread on this very subject that is over 4 years old and up to 600 posts now,
Onboard Sound Vs. Add in Sound Card - Guru3D.com Forums
Quote   Quote: Originally Posted by Lemur View Post
So very true. Also if your going to use a digital connection (coax or optical, doesn't matter), then unless there is a feature that is on a sound card over onboard (DDL for example) just use onboard as it then comes down to what is connected at the other end.
Similar help and support threads for2: onboard sound vs. Addon sound card
Solved S/PDIF Optical out - No sound from receiver (onboard and sound card) Sound & Audio
hdmi playback sound card or onboard? Sound & Audio
Realtek onboard sound card: Static/Crackling noises Sound & Audio
onboard sound card question Sound & Audio
Enabling onboard sound with a sound card Sound & Audio
Figuring out onboard sound card Drivers
