Can my sound card make 5.1 speakers work?
  1. Posts : 3,612
    you need one of these if you have a usb socket
    ZALMAN 5.1Ch USB Sound Card ZM-RSSC Sound card - 96 kHz - 24-bit
    Attached Thumbnails Attached Thumbnails Can my sound card make 5.1 speakers work?-usb-sound-card.png
  2. Posts : 9
    Windows 7 Ultimate x32
       #12
    Yep, only a 3.5mm jack pin (well, the size of any normal set of headphones, I don't know wether it's 3.5 but I suppose it is, sorry again I don't know the first thing about sound...)
  3. Posts : 3,612
    have you a usb?
  4. Posts : 9
       #14
    Ok, thanks a lot, so I've just got to buy an external sound card, install it and that's it? And should I use my HDMI connection if possible, or just stick to the normal jack pin?
    Anyway, thanks a lot for your help!
    And yes of course I've got USB^^
  5. Posts : 3,612
       #15
    you need a USB SOCKET to use the external sound card
    http://www.zalman.com/ENG/product/Pr...ad.asp?Idx=348
  6. Posts : 9
       #16
    I've got several USB sockets, don't worry^^ And is there any risk of the card not working with my computer, or should any external sound card do the job?
  7. Posts : 3,612
       #17
    i think it will ok read the zalman link its designed for notebooks ::: Zalman, leading the world of Quiet Computing Solutions :::
  8. Posts : 9
       #18
    Ok, well thanks a lot for your help
  9. Posts : 3,612
       #19
    no worrys post back how you get on and welcome again to the forums
  10. Posts : 9
       #20
    Yep, I should be getting my speakers & sound card next week, so I'll keep you posted :)
