Windows 7: USB generic audio driver Line level input
27 Dec 2010   #1
gliebisch
Windows 7 64-bit
How do you force the generic USB audio driver in Windows 7 to operate at LINE level instead of microphone level? My Audio Technica Turntable uses the generic driver and I have to run the microphone level all the way down to 4 (out of 100) in order to get the proper level. The old XP driver had a line-level selection tab but no such option in Windows 7.
27 Dec 2010   #2
Sardonicus
Windows 7 Home Premium 64 bit
Have you tried right clicking on the volume icon?
Recording devices> Microphone> Properties> Levels
27 Dec 2010   #3
gliebisch
Windows 7 64-bit
Quote   Quote: Originally Posted by p5bdkw View Post
I have. Have you looked there yourself? That opens up a level control that has to be brought all the way down to 4 (from 100) in order to get the level low enough to accept a line level input. Surely, Microsoft didn't put a LINE LEVEL button on the XP version and then regress to expecting users to just attenuate the microphone level waayyy down in the Windows 7 version? Since this is not a microphone, one would expect that somewhere else there is a line-level input that has to be enabled, or the Windows driver development just never got finished!
28 Dec 2010   #4
Sardonicus
Hello,
Yeah I did see it.
I'll toss another option out, maybe it can help.
Highlight Microphone,
Configure> Set up Microphone.
Good Luck!!
28 Dec 2010   #5
logicearth
Windows 8.1 Pro (x64)
Its not called a Generic driver for nothing. It doesn't know what is a microphone or a line-in device when connected via USB.
28 Dec 2010   #6
fireberd
Windows 7, 64 bit Home SP1, Win 8.1.1 Pro 64 bit
Why are you using the microphone? With a USB connection it uses it's own connection. I have a USB connected turntable and I have to be careful or it too will distort. You are not using the Microphone input (mono) or Line In (stereo) with a USB (digital) connection. The USB connected turntable I have, has a very high level (not really a good system) and for that reason I've went back to my regular stereo system turntable through my stereo system and use an analog signal through my sound card's Line In.
BTW, the AUDIO inputs on a PC are at "near line level", not low level like a guitar amp input or a standard mic input on a PA system or a standard "phono" level on a stereo system.
28 Dec 2010   #7
gliebisch
Windows 7 64-bit
Configure Microphone just brings up the "speech recognition" software, and offers no ability to make the USB signal a "line level" equivalent. I repeat: In the previous Windows XP implementation of the generic USB audio driver, there was a tab with a selection button marked "USE LINE LEVEL FEATURES ON THIS INPUT". No such option exists on the Windows 7 USB Audio driver. They just assume that all USB devices will be microphone level.
Fireberd: I think you missed my points entirely. I am NOT using a MICROPHONE, I am using the USB connection and the driver is assuming (incorrectly) this USB connection to be at microphone level. Typically, microphone levels are about 65 dB below "line level" signals. Microphone levels require high gain preamplification. It makes no sense to have to attenuate a signal by 65 dB just so the next stage can amplify it by 65 dB! This has been a principal of good audio design forever! I do not want to do like you and give up a digital input and go back to using the analog line in. That introduces its own artifacts, principally hum and noise.
For the same reason that analog inputs must have a choice of "mic" or "line" inputs, USB inputs must also have a switch in software that accomplishes the same thing. LOGICEARTH is correct in that a generic USB audio driver has no way of knowing whether the device is a microphone or a line level device, which is why the driver configuration needs to have that mic/line selection, JUST LIKE THE XP implementation did.
28 Dec 2010   #8
fireberd
I know about signal levels, I'm a musican, an ex amp tech and have my own computer based (Sonar) recording studio.
Computer mics are condenser mics and have a high level output, compared to a standard PA mic such as an SM58.
The USB turtable I have "Inovative Technology" does not have any provisions for any level adjustment. I can adjust the level with the recording programs I have such as what comes with Nero and the Creative (SoundBlaster) recording program. But even with those record level adjustments, it still seemed to be too high. That was the reason I went back to my Stanton turntable and my stereo system with the phono input (for RIAA equalization). Lately, I've been using my Focusrite Saffire Pro 40, firewire connected recording input for the turntable and recording with my Sonar DAW software. This is not for everyone but for me it turns out great.
28 Dec 2010   #9
gliebisch
Windows 7 64-bit
Fireberd,
You are experiencing the same problem I am when using USB. Your solution was to go back to the analog input, but I am trying to solve the USB digital input issue instead of bypassing it.
28 Dec 2010   #10
fireberd
Actually, the only reason I bought the USB turntable is that it will work with 78 RPM records and I have about 30 that I want to digitize.
There was other reasons for going back to the Stantron turntable, it has a variable speed control that the cheap USB turntable I have does not and the needle and cartridge are a higher quality.
