Windows 7: static from front audio jack??????
27 Dec 2010   #1
sogone209
Windows 7 Professional x64 (6.1.7600)
i have a acer ax1700-u3700 desktop computer. the front audio jack makes a static audio noise when moving the mouse. but when im not moving it it doesnt make noise. its worse when i click the start button and look threw the stuff on the menu. all drivers are current. upgraded bios to lastest at least i think. help plz
27 Dec 2010   #2
linnemeyerhere
Windows 7 Ultimate 64
sogone209,
My first thought is to have you make and unmake the connection into that front plug many times and even hit it with air or better yet to use a little contact enhancer on the pin and make and unmake the connection. What happens is if the connections are barely being made then noise and interference can make it's ugly and noisy presence known.
27 Dec 2010   #3
sogone209
i have cleaned out the port with air and cleaner? it seems as if its a static issue? with other things on my computer? like when my hd thinks it creats a static sound to my audio. i wonder how to fix this. cause my read audio jack is crystal clear. but i have my 5.1 hooked to that so i dont wanna keep switchin it for my headphoens so i use the front
27 Dec 2010   #4
linnemeyerhere
This sounds literally like an internal issue and one that you won't have a driver work around on. Have you opened the case and checked the front ports connection to the mobo, I would unmake and make that connection and also see if you can route the audio ports leads in a different manner to reduce stray electrical signals.
27 Dec 2010   #5
sogone209
i have tried this before but on to the front of the audio jacks have i disconnected. should i disconnect both sides and wipe them off?? but also turn the computer off???
27 Dec 2010   #6
linnemeyerhere
Yes please turn the computer off then check both sides.
Similar help and support threads for2: static from front audio jack??????
Front jack not working for Realtek HD Audio on Windows 7 Sound & Audio
Front I/O Audio Jack not working. Sound & Audio
Solved Front audio headphone jack reversed stereo... Sound & Audio
Solved Static noises in front audio port Hardware & Devices
can't set front jack as default audio output (notebook) Sound & Audio
