Windows 7: 5.1 Sound card not working
24 Mar 2011   #1
danasegarane
Microsoft Windows 7 (6.1) Ultimate Edition ,Previously Windows XP
Hello All,
I just bought Tech-Com 5.1 Sound card and inserted the sound card in slot.
After insertion the sound not detected..
Please help
24 Mar 2011   #2
Morph666
Windows 7 Ultimate 64-Bit
Go here Realtek and download & install AC'97 Audio Codecs (Software). If they don't work, download & install High Definition Audio Codecs (Software) instead.
24 Mar 2011   #3
stormy13
Microsoft MVP
Win 7 Ultimate x64
Quote   Quote: Originally Posted by Morph666 View Post
They won't work. If you had clicked the link to that card it quite clearly says that it has the C-Media CMI8738 chip on it, not Realtek.
In all likelihood you're probably asking a lot from a sound card that was first made somewhere close to ten years ago, and at best has limited (if any) Windows 7 support. Looking at what passes for the Tech-Com download page, they don't even have Vista drivers for that card.
C-Media did release a Vista driver and a beta driver for Windows 7 for it,
C-Media Electronics, Inc.
Unfortunately you need an account at C-Media to download them, and not having much luck finding them elsewhere.
25 Mar 2011   #4
danasegarane
Installed both and not working,,,
02 Apr 2011   #5
danasegarane
I Installed the driver and it is not producing the output in 5.1 card. But produce in normal card
02 Apr 2011   #6
Sardonicus
Windows 7 Home Premium 64 bit
Have you checked your levels?
Make sure you pull the slider down to see all available channels.
