Can't record audio from Stereo Mix
  1. Posts : 7
    See the title. For a while now, I've been trying to record audio that output from my speakers, but have been unsuccessful. I have already activated Stereo Mix and am trying to record from it, but nothing comes out. Interestingly, the green bar in Sound Options next to Stereo Mix DOES fluctuate, I am just unable to record what comes out.
    If more information is needed, ask and I'll give it.
    Help would be immensely appreciated as I have tried many solutions past that and none of them have worked!
  2. Posts : 1,009
    Windows 7 Ultimate 64 bit SP1
    What are you trying to record with? I would suggest aduacity to do this job, but i dont really know what is the purpose.
    Do you have realtek audio?
  3. Posts : 7
    It's not the recording program. I have audacity, and I've also tried it with a number of other programs. None of it works.
    And yes, I have realtek audio.
  4. Posts : 1,009
    So i guess you have updated the driver from here.
    I'll be back ina minute.
  5. Posts : 7
    yes, I do have that driver update.
  6. Posts : 1,009
    I can't say that this, or that is the problem so you will have to go through some troubleshooting..
    Open cpanel/Sound open your stereo mixer and disable all sound effects, set the level to 50, and tick both options und the advanced tab.
    Open audacity /properties set record device to stereo mixer. Play back something and hit the record button.
  7. Posts : 1,009
    Under Sound / communications select 'do nothing'.
  8. Posts : 7
    Done that. Still nothing...
  9. Posts : 1,009
    Go to your speaker/levels and put everything to 100, if still nothing happens than it could be a hardware problem.
  10. Posts : 8,135
    There could be some corruption between the sound and Windows. Go to the Device Manager and uninstall the sound device (DO NOT check the box to uninstall the drivers). Then restart the PC and when Windows starts it will detect and reinstall the sound. This fixes a lot of flakey problems and may take care of your problem.
    Also, make sure whatever recording program you are using is set to get it's input from the System Mixer.
