Windows 7: Hotkeys for sound volume?
25 Jul 2009   #1
MTCH
Hello, as I have a ntb without buttons for controlling sound volume, I have installed a program called Sound volume hotkeys - it allows to control volume with hotkeys: WIN + UP (resp. DOWN). The problem is that Win 7 has "occupied" the hotkeys, is there a way how to change it? I do not need the function by Win 7 (maximize restore/minimize) at all. Thx.
25 Jul 2009   #2
stormy13
Microsoft MVP
Win 7 Ultimate x64
Tried using the options/settings in the program to change what key(s) are used? From the looks of it here (last screen shot),
Active Keys - Keyboard Shortcuts (Hotkeys) Manager
it does.
25 Jul 2009   #3
MTCH
Active keys is a different program, must run all the time to work, moreover it is only a trial version. I tried it but it is not a solution.
Is not there a way how to disable the windows hotkey? E.g. in registry...?
25 Jul 2009   #4
stormy13
Microsoft MVP
Win 7 Ultimate x64
Assuming it is the same in Vista as 7,
http://www.vistax64.com/tutorials/77...s-hotkeys.html
25 Jul 2009   #5
johngalt
warning   Warning
Be advised this will disable all windows hotkeys - if you use some others they will no longer be accessible as well.
25 Jul 2009   #6
stormy13
Microsoft MVP
Win 7 Ultimate x64
Just had a look at the manual for your laptop and I guess yours is one of those "select models" that doesn't have the volume and mute keys,
Quote:
Adjusting the Volume
You can adjust the volume using any of the following controls:
■ Notebook volume buttons (select models only)
❏ To mute or restore volume, press the volume mute button.
❏ To decrease the volume, press the volume down button.
❏ To increase the volume, press the volume up button.
■ Windows volume control:
1. Click the Volume icon in the notification area (at the far
right of the taskbar).
2. Increase or decrease the volume by moving the slider up
or down. (You can also click the check box next to Mute
to mute the volume.)
or
1. Double-click the Volume icon.
2. In the Volume Control column, increase or decrease the
volume by moving the Volume slider up or down. You can
also adjust the balance or mute the volume.
✎Volume can also be adjusted within some applications.
If the Volume icon is not in the notification area, follow the steps
below to place it in the notification area.
1. Select Start > Control Panel > Sounds, Speech, and Audio
Devices > Sounds and Audio Devices.
2. Click the Volume tab.
3. Select the Place volume icon in the taskbar check box.
4. Click Apply.
25 Jul 2009   #7
MTCH
to Stormy13: You are right, the only way how to control sound on my HP Compaq nx6110 with Windows according to a manual is windows volume control (in tray), which is not very practical.
Sometimes I need win hotkeys, so disabling all the win hotkeys is not the best solution for me. I will probably try to find a similar program to Sound Volume hotkeys.
25 Jul 2009   #8
johngalt
Another option would be to use a utility like HoeKey (admittedly very old, but I like it because of its configurability) or ZenKey to re-create those hotkeys you do use by yourself - but both f those are also apps that stay running all the time.
22 Nov 2009   #9
REB
Windows 98 SE
Hey bro i dunno if this is a little late but if you are still interrested in using the program in win7 without messing up hotkeys, have a look here:
Sound Volume Hotkeys for Windows 7 - SPICY LAVA
Similar help and support threads for2: Hotkeys for sound volume?
Solved Low volume with new sound card(Creative Sound Blast 5.1 VX) Sound & Audio
anyway to use hotkeys to switch sound output? Customization
Volume On, No Sound. Sound & Audio
The volume bar shows sound but no sound through speakers. Sound & Audio
Low Sound Volume Sound & Audio
Volume all the way down, still sound! Sound & Audio
Solved Low sound volume Sound & Audio
