How to assign applications to different sound outputs
  1. Posts : 27
    Windows 7 x64 build 7600 RTM
    Hello,
    I use my pc to watch movies. It is connected to my tv via hdmi and sound system via SPDIF optical cable. Everything works fine, but sometimes I want listen to music or other apps through my headphones, while someone else listens through sound system.
    How can I do that?
    Windows 7 volume mixer shows both outputs and I can control the sound of different apps and mute them, but I can't assign specific applications (music player, browser) to other sound outputs.
    One time the browser was assigned to speakers (headphones) rather than SPDIF, but I couldn't assign apps myself.
    Thanks in advance.
  2. Posts : 6,075
    Windows 7 Professional 64 bit
    Do you have the onboard sound plus a 2nd added sound card?
    If not then you won't be able to split 2 different types of Audio to different sources.
    You can assign the source of the one sound you wish to listen to though, just go to start>control panel>sound, you will then see the picture below.
    Just right click on the one you want to use for the output and set as default device.
    Attached Thumbnails Attached Thumbnails How to assign applications to different sound outputs-sound.png
  3. Posts : 27
    I have only onboard sound and strangely I could hear two different streams at the same time. My brother was watching a movie via home theater and I was watching youtube videos, hearing them through headphones. So I know it's possible, don't know how though . Maybe because the pc doesn't actually encode the movie audio, it only streams via spdif cable and the home theater does the rest.
    I'm just trying to find a way to assign a browser to simple speakers rather than spdif and not disturb people watching a movie.
  4. Posts : 3
    Hello, I have USB speakers and onboard, I like to play spotify in the USB speakers and other stuff on the onboard SC.
    but all applications just follows the default setting
