Creative Sound Blaster X-Fi Xtreme Audio PCI - microphone problem
  1. Posts : 3
    Win 7 64
    Hello there. Yesterday i've installed this sound card and everything works fine but no microphone. I can see it in control panel but it doesn't work. Mic is fine as i was using it before. I have Win 7 64bit.
    If you have any idea what can cause the issue please help, if nothing will work i will simply send it back to shop ;/
  2. Posts : 123
    win 7 pro x64
    What programs are you running to test it?
    If your just not hearing yourself, in windows then it's the option there for listen to what you hear.
  3. Posts : 3
    Win 7 64
    I was checking it by windows microphone set program and TS
  4. Posts : 3
    Win 7 64
    What i did now is turn on my audio card on MoBo and mic is working there. I could leave it like this so i have good sound from SB and working mic on old card but its not how it should be...
