Windows 7: Does anyone have advice for using an external sound card?
01 Nov 2012   #11
Spritsailor
Windows 7 Home Premium 64-bit
Do you have any "Sound Enhancements" enabled. My RealTek and many others have some options for enhancements such as echo, reverb, chorus.
"Recorded music" is bad. What happens if you play a commercial audio CD? Or some other audio from the internet?
Also, what program are you using to record, and what are you recording?
There are no sound enhancements that I am aware of. If I just listen to music it sounds perfect. When I try recording on this Toshiba Satellite with the "sound recorder" or another program like Roxio it gets garbled. That same Roxio program on my old computer recorded beautifully. I am recording music from either Youtube or my Zoom recorder I use to record live music. Played through my stereo that Zoom sounds perfect. When I record it on my computer it gets garbled.
01 Nov 2012   #12
fireberd
Windows 7, 64 bit Home SP1, Win 8.1.1 Pro 64 bit
OK. So its just recorded music that is bad.
In the Sound Panel, Recording section. You should have Stereo Mix or System Mixer (both are the same). Doubleclick on that and it will bring up the Stereo Mix (or whatever yours is called) panel. In mine there is an enhancements tab (section) that enhancements can be enabled or disabled. Check yours to see if there is something there.
01 Nov 2012   #13
Spritsailor
There is only a Stereo Mixer on the Playback. There is no Stereo Mixer on the Recording Section. The only thing I get when I click on the microphone in that section is a way to configure the speech recognition stuff. I did click on properties and see that there is a Microphone Boost in that section. I turned down the microphone boost from 24 dB to 12 dB.
01 Nov 2012   #14
Spritsailor
I tried recording again with the Microphone boost down and this time it came out crystal clear for 25 seconds, then sounded underwater/garbled again.
01 Nov 2012   #15
fireberd
There should not be a Stereo Mixer on the Playback. If there is there is a major problem. The Default Playback device should be set to your "Speakers" (the Connexant integrated audio device). However, you should have Stereo Mixer in the Recording section. Bring up the Sound panel/Recording section and then RIGHT click in an empty space in the panel and then check the boxes to show disabled devices and disabled devices. If the Stero Mixer is now shown, enable it and make it the default recording device.
01 Nov 2012   #16
Spritsailor
I have it up now....the choices in recording section properties is General, which says it's working normally, Listen, which is set to "default playback device" with "speakers conexant smartaudio HD" as an alternative. It's set on "default playback device". Levels where the mic and boost are located and Advanced where I see there is an "audio enhancements" box that is checked. NO stereo options in the Recording section.
01 Nov 2012   #17
fireberd
Here is what I have for the Playback and Recording panels. You should have something close to these.
02 Nov 2012   #18
Spritsailor
All I have on mine are speakers and microphone. No realtek or stereo mix.
02 Nov 2012   #19
fireberd
This appears to be the sound download for your model. Suggest you download and install it, even if its the same driver that you have.
Conexant driver 8.51.1.0a
http://www.csd.toshiba.com/cgi-bin/t...ily=1073768663
02 Nov 2012   #20
boohbah
Right click an area of the sound/record window and select show hidden or disabled items ,
I'm using my phone to post so I can't give you the exact terms ,but you should see similar when you right click,
Similar help and support threads for2: Does anyone have advice for using an external sound card?
Sound card advice Sound & Audio
external sound card advice for use with monitor speakers Sound & Audio
Just looking for some sound card advice and suggestions Sound & Audio
Using an External Sound card Sound & Audio
Looking to buy a new external/usb sound card Sound & Audio
Sound Card Advice Sound & Audio
