Windows 7: NO SOUND TROUGH HDMI ON ACER AX3400-U3032 and No HDMI Icon in sound se
22 Mar 2013   #1
Devildog90
Windows 7 premium Home edition
Had to replace motherboard from authorized acer parts dealer now I get no sound through HDMI port. I did through the original board until it got fried by electrical surge. Can any one help or send me a picture of the inside the same model to make sure all jumpers on the motherboard are in the right spot. Or if any one else had this problem tell me how you fix it. It does not have HDMI sound icon in the mixer. What I have done:
1. I have looked for disabled devices.
2. Tried looking in sound mixer settings for the default audio.
3. New install and drivers.
4. Tried a system utility software RegInOut. Looking for serious replies on fix even if it was not an Acer.
specs:
AMD Athlon II X4 Quad-Core Processor 640,
Windows 7 Home Premium,
NVIDIA GeForce 9200 Chipset, NVIDIA GeForce 9200 Graphics Integrated ,
4096MB DDR3 Memory,
1TB SATA Hard Drive (Green Product – variable RPM),
16X DVD±R/RW SuperMulti Drive,
Multi-in-1 Digital Media Card Reader,
802.11b/g/n Wireless,
High Definition Audio with 5.1-Channel Audio Support,
Any help appericated
22 Mar 2013   #2
Bongo
Win 7 Pro x64 / Win 8.1 Pro
Welcome to the Seven Forums
One thing you could try is to open up the Control panel then click on Sound and then go to the Playback tab and see if there is anything in there to enable it that's what I had to do on my laptop.
Jerry
24 Mar 2013   #3
Devildog90
I have tried and it is still not there and not disable I am stumped?
24 Mar 2013   #4
caperjack
win8pro 32 bit win 7Ulitmate 32 bit
did you have to reinstall windows after the new board was installed ,if yes did you install chipset drivers [ preferably from the manufacturers website or the acer site ]for the new board .
27 Mar 2013   #5
Devildog90
yes I did install ship set drivers from acer and nvidia nothing is helping
28 Mar 2013   #6
Bongo
Was the motherboard replaced under warranty? Maybe you have a defective new motherboard.
Jerry
28 Mar 2013   #7
Devildog90
No not under warranty, this is the third motherboard I have replaced in 4 weeks because the icons do not show up. I thought the same, bad motherboard. But the motherboard is fine. what would the chances be to have 3 bad boards. I am missing a driver or something is not enabled. I just dont know what I have only one sound icon the speaker. i do not get the digital output spdif and my tv does not show up in list. They are not hidden and they do not show up as disabled. I et get a Picture through HDMI but no sound.
28 Mar 2013   #8
Bongo
It may be a pretty slim chance but three motherboards in four weeks I wouldn't rule out a forth.
Post a screenshot of your sound property window with the Playback tab like in my post #2 above.
Also post a screenshot of Device Manager.
Use these tutorials for posting screenshots.
Screenshot with Paint
How to Use the Snipping Tool in Vista - Vista Forums
Jerry
28 Mar 2013   #9
Devildog90
Here are screen shots
28 Mar 2013   #10
Devildog90
more pictures
Similar help and support threads for2: NO SOUND TROUGH HDMI ON ACER AX3400-U3032 and No HDMI Icon in sound se
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent Sound & Audio
No sound through speakers.Jack not being detected.HDMI sound only? Sound & Audio
no sound through tv via hdmi, sound plays through laptop speakers (idt Sound & Audio
No sound via audio jacks, but sound via hdmi. Sound & Audio
