Windows 7: Need help with AUDIO IN jacks..
01 Dec 2009   #1
Jason
Windows 7 x64
I have an M9350f elite series from HP. There are audio IN jacks in the back of the tower and two in the front.
I'm trying to hook my PS3 component cables up to my tower and play the sound through my speakers, but whatever I try does not work.. the PS3 is outputting sound via component cables..
I'm seriously getting really pissed right now.. I've tried getting this to work with HDMI-to-DVI and nothing is working........
It's extremely hard to write a detailed and flamboyant post when angered, I'm sorry.. but could someone offer me any insight to get this to work?
01 Dec 2009   #2
torrentg
7600.20510 x86
The computer most likely has 1/8" inch stereo input and the PS3 has dual mono RCA type outputs.
You'll need a converter cable to take the two RCA male plugs to make it into a 1'8" stereo male plug. Radio Shack has this.
02 Dec 2009   #3
Jason
Windows 7 x64
Yay for random adapter in my closet.. I was like, "hey I think I seen something with a red and white female connector on it.." -- searched my closet, and viola! I have the 2 RCA inputs going into an adapter which has a green female input, not sure what kind of input it is.. looks like 1/8"? But it goes directly into my speakers instead of using my PC.
Thanks for sparking an idea in my brain..
Similar help and support threads for2: Need help with AUDIO IN jacks..
Is there a way to enable both optical audio and the stereo jacks? Sound & Audio
Cannot get audio on any jacks. Sound & Audio
Gigabyte ga-z68ma-d2h-b3 audio jacks not working. Drivers
No Audio Output via Front and Rear Jacks Sound & Audio
audio jacks Sound & Audio
