Windows 7: No sound when burning avi to dvd.
17 Dec 2009   #1
NSHabsFan
Hey There,
Just got a new machine with Windows 7, burned 2 dvd's from avi files and they worked fine, now when i use Windows to burn a dvd from an avi (even tried one of the ones that had worked previously), I get no audio on the DVD, and it doesn't matter if I watch it on the computer or in a DVD player. The avi plays fine on the PC ... Any help appreciated!
17 Dec 2009   #2
zigzag3143
Win 8 Release candidate 8400
Quote   Quote: Originally Posted by NSHabsFan View Post
Hey There,
Hi and welcome
What are you using to burn the dvd?
type device manager in search go to the sound tab. Is your device listed there? does it have a yellow triangle on it? are there any other "unknown" devices with yellow on them
Ken J+
17 Dec 2009   #3
whs
Microsoft MVP
Try burning with this program ( DVD Flick ). If it is still not working, then we have to look for a system setting problem.
17 Dec 2009   #4
darkassain
also what codec was the audio using to render the audio?
20 Dec 2009   #5
NSHabsFan
Everything is fine with the hardware.
I was really hoping to be able to use the native support in Windows to burn the movies as its quite simple for my mother to learn.
Not sure about the codec, how would I find that info?
20 Dec 2009   #6
NSHabsFan
I get the feeling that it was a windows update that caused the issue, but just not sure which one ... just a thought
20 Dec 2009   #7
stormy13
Microsoft MVP
Win 7 Ultimate x64
Quote   Quote: Originally Posted by darkassain View Post
Bingo, Windows DVD Maker while good at what it does, is too limited in the formats that it supports. As whs linked to, give DVD Flick a try. Much more robust program than WDM and not very hard to use,
DVD-Guides.com - How to convert any video format to DVD using DVD Flick
For the most part it is just a matter of selecting the file you want to convert and letting it do its thing. The default settings in are enough to go on for a basic conversion, only need to get into the advanced settings if you want to get fancy.
20 Dec 2009   #8
NSHabsFan
Funny it worked for the first two burns, and then quit. I'll give the DVD Flick a try and let you know.
Thanks for the replies.
21 Dec 2009   #9
NSHabsFan
DVD Flick worked great.
Still curious as to why the native windows dvd maker stopped working, oh well, its working anyway.
Thanks again!
21 Dec 2009   #10
whs
Microsoft MVP
Good, I am glad you are all set.
Similar help and support threads for2: No sound when burning avi to dvd.
burning dvd's General Discussion
Burning avi results in DVD with no sound. New Problem. Music, Pictures & Video
Need Help with burning a dvd Music, Pictures & Video
Burning to DVD Music, Pictures & Video
Burning .VOB Software
Windows 7 Native Burning OK, other burning apps NOT OK Software
Burning cd's and DVD's General Discussion
