Windows 7: Don't know were to put audio cable in hd sound input
22 Dec 2009   #1
ritesh
I got a Compaq Persario V3000
and I have a Digital Audio (S/PDIF) built in my laptop and I don't know were to put my sound cable.
There are two Speakers which I know were to put them
but for Digital Audio (S/PDIF) it say it is located in the Rear Panel jack
Please help me.I know it is located but I don't know were it is on my laptop.
Many thanks,
Ritesh
22 Dec 2009   #2
Dwarf
Windows 8.1 Pro RTM x64
Hi ritesh,
Depending on how you have got your system configured, the audio out socket can provide both analog and digital output.
22 Dec 2009   #3
ritesh
Have a look at it
I know that my Speakers are default but still
22 Dec 2009   #4
Jonathan_King
Windows 7 Professional x64
Hello Ritesh,
The mic jack is usually pink.
~Jonathan
22 Dec 2009   #5
ritesh
Quote   Quote: Originally Posted by Jonathan_King View Post
Hello Ritesh,
~Jonathan
Thanks,But I need to know were to put the hd sound input.I know were to put the Speakers(Green) input but were to put HD sound
22 Dec 2009   #6
Jonathan_King
I doubt that your laptop has an HD jack. You can try Googling your laptop, and seeing if you can find a user manual.
Sorry I can't be of more help,
~Jonathan
22 Dec 2009   #7
stormy13
Microsoft MVP
Win 7 Ultimate x64
You're right, it doesn't. You can see it here (have a look at the "Notebook Tour Guide"),
Manuals for Compaq Presario V3000 CTO Notebook PC - HP Customer Care (United States - English)
all it has is a a single audio out and single line in/mic jack (both analogue). I would also say that from the looks of the screen shot that ritesh that he hasn't installed the drivers for the sound yet, and is just running on whatever default driver that Windows installed. He doesn't say whether it is 32 or 64 bit, but you can get the Vista driver (no 7 driver listed, but the Vista one should work) here,
Select your operating system Compaq Presario V3000 CTO Notebook PC - HP Customer Care (United States - English)
22 Dec 2009   #8
ritesh
Quote   Quote: Originally Posted by stormy13 View Post
windows 7 (32bit)
Similar help and support threads for2: Don't know were to put audio cable in hd sound input
No audio... after changing heat sink? (on-board audio, input is ok) Sound & Audio
Problem with sound device with audio input. Sound & Audio
Connecting "HD audio" cable from front panel to sound card Sound & Audio
Sound stops when changing audio input problem Sound & Audio
Realtek HD Audio, PC input yes/ HDTV input no Sound & Audio
