Windows 7: Sound Static Help (removes most static)
18 Jan 2010   #1
Undoubt
Win 7
Stumbled upon this trying to fix my static and it helped it out a bit, not 100% though but thought i would share it.
Anyways;
goto your playback devices > click your speaker properties > advanced > and change the default format to a higher setting, such as 24 bit, 48000hz (studio quality)
thats it, and of course you can play around; if you have an alright sound-system you can tweak your eq. settings and such to compensate for playback quality.
18 Jan 2010   #2
Nikolay
Windows 7 Ultimate x64 | Windows XP Pro x86 | Windows Vista Ultimate x86
Thanks for the tip but did not help me.
Similar help and support threads for2: Sound Static Help (removes most static)
Sound static problems! Sound & Audio
Static for all sound Sound & Audio
Help with static sound Sound & Audio
Sound static/ lag Sound & Audio
Realtec Sound card. Fuzzy/static sound Sound & Audio
