Windows 7: Not reading sound card
07 Mar 2010   #1
yakashamonian
So, I recently upgraded from XP64 bit to Windows 7 32bit (Because 64bit sucks there's like no drivers for anything)
Anyway, I noticed when i had things set up and went to Youtube it wasn't reading my sound. Eventually I went to Dxdiag to find out what soundcard I have, and turns out it doesn't even read I have it.
It's a MSI motherboard, and my speakers are 5.1 logitech, I don't know nor can really find out any information besides this, I downloaded a device finder, but it couldn't see the soundcard either to search for drivers if it was a driver problem.
So I'm not sure what to do other than buy another sound drive, which is kind of lame since this mother board costed me 300 bucks and I've only used it for a year.
Is there any suggestions of what I can do.
07 Mar 2010   #2
BugMeister
64-Bit W7 Ult_sp1
you won't see the soundcard in the actual DXdiag itself - but it will appear in the printout..
did you save all information after doing the DXdiag, if so it will appear in the info produced..??
the saved file will drop onto your desktop by default, and is readable via Notepad..
BTW. there is no shortage of 64-Bit drivers..
07 Mar 2010   #3
zigzag3143
Win 8 Release candidate 8400
Quote   Quote: Originally Posted by yakashamonian View Post
You probably only need a driver. go into device manager (type device manager in search) look at the sound tab and see if there is a driver present and working properly.
Let us know the results
Ken
07 Mar 2010   #4
yakashamonian
Mmk
Bug: Alright I'll check a print out, and I dunno if there is for Windows 7 64bit or not. However I know on XP64 my cam wouldn't work and there were no drivers that'd let it work, MSN 9 wouldn't load on it said it doesn't work for the OS and a couple of other things, it was to much hassle to trust Windows 64bit.
ZigZag: I check, there was something that said "High Definition Audio Device" and says it's working properly.
08 Mar 2010   #5
BugMeister
64-Bit W7 Ult_sp1
- could you post up the DXDiag printout, please
- it might hold the necessary information to enable someone to trace the driver for you..
08 Mar 2010   #6
yakashamonian
Quote   Quote: Originally Posted by BugMeister View Post
System Information
Time of this report: 3/6/2010, 19:34:18
       Machine name: FALCON-PC
   Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_gdr.091207-1941)
           Language: English (Regional Setting: English)
System Manufacturer: INTELR
       System Model: AWRDACPI
               BIOS: Phoenix - AwardBIOS v6.00PG
          Processor: Intel(R) Pentium(R) D CPU 3.40GHz (2 CPUs), ~3.4GHz
             Memory: 2048MB RAM
Available OS Memory: 2046MB RAM
          Page File: 1432MB used, 2660MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No sound card was found.  If one is expected, you should install a sound driver provided by the hardware manufacturer.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: Radeon X1300 / X1550 Series (Microsoft Corporation - WDDM)
       Manufacturer: ATI Technologies Inc.
          Chip type:
           DAC type: Internal DAC(400MHz)
         Device Key: Enum\PCI\VEN_1002&DEV_7142&SUBSYS_070017EE&REV_00
     Display Memory: 1278 MB
   Dedicated Memory: 511 MB
      Shared Memory: 767 MB
       Current Mode: 1280 x 1024 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: AL1706
         Monitor Id: ACRAD46
        Native Mode: unknown
        Output Type: HD15
        Driver Name: atiumdag.dll,atiumdva.cap,atitmmxx
Driver File Version: 8.14.0010.0630 (English)
     Driver Version: 8.56.1.15
        DDI Version: 9Ex
       Driver Model: WDDM 1.0
  Driver Attributes: Final Retail
   Driver Date/Size: 7/13/2009 17:14:55, 4030976 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B71EE2-3202-11CF-2876-0A27A1C2C535}
          Vendor ID: 0x1002
          Device ID: 0x7142
          SubSys ID: 0x070017EE
        Revision ID: 0x0000
 Driver Strong Name: atiilhag.inf:ATI.Mfg.NTx86...1:ati2mtag_RV515:8.56.1.15:pci\ven_1002&dev_7142
     Rank Of Driver: 00F42001
        Video Accel: ModeMPEG2_A ModeMPEG2_C
   Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
       D3D9 Overlay: Not Supported
            DXVA-HD: Not Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description:
 Default Sound Playback: No
 Default Voice Playback: No
            Hardware ID:
        Manufacturer ID:
             Product ID:
                   Type:
            Driver Name:
         Driver Version:
      Driver Attributes:
            WHQL Logo'd:
          Date and Size:
            Other Files:
        Driver Provider:
         HW Accel Level: Emulation Only
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: USB Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x1241, 0x1603
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27CA
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/13/2009 15:52:09, 258560 bytes
| Driver: usbd.sys, 7/13/2009 15:51:05, 5888 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 7/13/2009 15:45:09, 28160 bytes
| Driver: kbdclass.sys, 7/13/2009 17:20:36, 42576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/13/2009 15:11:24, 80896 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x1267, 0x0213
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/13/2009 15:45:08, 26112 bytes
| Driver: mouclass.sys, 7/13/2009 17:20:44, 41552 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 7/13/2009 17:19:10, 51776 bytes
| Driver: sermouse.sys, 7/13/2009 15:45:08, 19968 bytes
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 48.9 GB
Total Space: 114.5 GB
File System: NTFS
      Model: WDC WD1200BB-00RDA0 ATA Device
      Drive: D:
      Model: PLEXTOR DVDR   PX-750A ATA Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/13/2009 15:11:26, 108544 bytes
System Devices
     Name: Intel(R) ICH7 Family Ultra ATA Storage Controllers - 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_71761462&REV_01\3&2411E6FE&1&F9
   Driver: C:\Windows\system32\DRIVERS\intelide.sys, 6.01.7600.16385 (English), 7/13/2009 17:20:36, 15424 bytes
   Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 17:19:03, 42560 bytes
   Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 17:26:15, 21584 bytes
   Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/13/2009 17:26:15, 133200 bytes
     Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_71761462&REV_01\3&2411E6FE&1&E9
   Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/13/2009 15:51:10, 24064 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 15:51:15, 284160 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/13/2009 15:52:09, 258560 bytes
     Name: RAID Controller
Device ID: PCI\VEN_1106&DEV_3164&SUBSYS_71581462&REV_06\4&38303207&0&20F0
   Driver: n/a
     Name: Intel(R) N10/ICH7 Family SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_71761462&REV_01\3&2411E6FE&1&FB
   Driver: n/a
     Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_71761462&REV_01\3&2411E6FE&1&E8
     Name: Radeon X1300 / X1550 Series Secondary (Microsoft Corporation - WDDM)
Device ID: PCI\VEN_1002&DEV_7162&SUBSYS_070117EE&REV_00\4&81F6ADB&0&0108
   Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.0859 (English), 7/13/2009 14:09:17, 4194816 bytes
   Driver: C:\Windows\system32\DRIVERS\ativcaxx.cpa, 6/10/2009 13:19:15, 328162 bytes
   Driver: C:\Windows\system32\DRIVERS\ativcaxx.vp, 6/10/2009 13:19:15, 929 bytes
   Driver: C:\Windows\system32\DRIVERS\ativvpxx.vp, 6/10/2009 13:19:15, 52400 bytes
   Driver: C:\Windows\system32\DRIVERS\ativpkxx.vp, 6/10/2009 13:19:15, 2096 bytes
   Driver: C:\Windows\system32\DRIVERS\ativokxx.vp, 6/10/2009 13:19:15, 2096 bytes
   Driver: C:\Windows\system32\DRIVERS\ativdkxx.vp, 6/10/2009 13:19:15, 2096 bytes
   Driver: C:\Windows\system32\atiumdag.dll, 8.14.0010.0630 (English), 7/13/2009 17:14:55, 4030976 bytes
   Driver: C:\Windows\system32\atiumdva.dll, 7.14.0010.0208 (English), 7/13/2009 17:14:57, 4772352 bytes
   Driver: C:\Windows\system32\amdpcom32.dll, 7.14.0010.0018 (English), 7/13/2009 17:14:53, 50688 bytes
   Driver: C:\Windows\system32\atiumdva.cap, 6/10/2009 13:19:14, 69112 bytes
     Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_176A1462&REV_01\3&2411E6FE&1&D8
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 15:50:56, 108544 bytes
     Name: Intel(R) N10/ICH7 Family Serial ATA Storage Controller - 27C0
Device ID: PCI\VEN_8086&DEV_27C0&SUBSYS_71761462&REV_01\3&2411E6FE&1&FA
     Name: Radeon X1300 / X1550 Series (Microsoft Corporation - WDDM)
Device ID: PCI\VEN_1002&DEV_7142&SUBSYS_070017EE&REV_00\4&81F6ADB&0&0008
     Name: Intel(R) N10/ICH7 Family PCI Express Root Port - 27D4
Device ID: PCI\VEN_8086&DEV_27D4&SUBSYS_27D48086&REV_01\3&2411E6FE&1&E2
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 17:20:45, 153680 bytes
     Name: Intel(R) ICH7 Family LPC Interface Controller - 27B8
Device ID: PCI\VEN_8086&DEV_27B8&SUBSYS_27B88086&REV_01\3&2411E6FE&1&F8
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 17:20:43, 13888 bytes
     Name: Intel(R) N10/ICH7 Family PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_27D08086&REV_01\3&2411E6FE&1&E0
     Name: Intel(R) 945G/GZ/GC/P/PL PCI Express Root Port - 2771
Device ID: PCI\VEN_8086&DEV_2771&SUBSYS_00008086&REV_81\3&2411E6FE&1&08
     Name: Intel(R) N10/ICH7 Family USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_71761462&REV_01\3&2411E6FE&1&EF
   Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/13/2009 15:51:14, 41472 bytes
     Name: Intel(R) 945G/GZ/GC/P/PL Processor to I/O Controller - 2770
Device ID: PCI\VEN_8086&DEV_2770&SUBSYS_71761462&REV_81\3&2411E6FE&1&00
   Driver: n/a
     Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_71761462&REV_01\3&2411E6FE&1&EB
     Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_244E8086&REV_E1\3&2411E6FE&1&F0
     Name: Intel(R) N10/ICH7 Family USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_71761462&REV_01\3&2411E6FE&1&EA
     Name: Intel(R) PRO/1000 PL Network Connection
Device ID: PCI\VEN_8086&DEV_109A&SUBSYS_176C1462&REV_00\4&2A9E0036&0&00E2
   Driver: C:\Windows\system32\DRIVERS\e1e6032.sys, 9.13.0004.0010 (English), 7/13/2009 14:02:50, 211456 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16385
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7600.16385
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7600.16385
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7600.16490
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7600.16385
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7600.16385
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16385
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16385
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
WDM Streaming Communication Transforms:
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
08 Mar 2010   #7
BugMeister
64-Bit W7 Ult_sp1
Have you enabled the onboard sound in BIOS..??
Your motherboard manual should tell you how to access the BIOS in order to change the settings that your computer uses when it boots up..
- one of these settings relates to the onboard sound device
Warning: do not mess around with the BIOS settings unless you are confident that you know exactly what you are doing..
08 Mar 2010   #8
yakashamonian
I'm screwed then my brother ended up throwing away my manual back a year ago X_X
08 Mar 2010   #9
MisterActorMan
I've worked BIOS on 10 different pcs and they're all pretty simple and the same...Just hit the appropriate key during bootup (Delete, F10, F11, or something) and go into BIOS. You navigate around with the keyboard arrows and use enter to change the highlighted selection.
In the BIOS, navigate to the tab that seems appropriate for your issue and browse through the options for motherboard sound devices. There shouldn't be too many.
Make sure you can navigate to the EXIT tab and select "Exit and Discard Changes," or "Exit Without Saving," in case you think you screwed something up. Then you can just exit and not have screwed it up, because you won't have saved whatever changes you made!
08 Mar 2010   #10
BugMeister
64-Bit W7 Ult_sp1
- have no fear, all is not lost..
- if you can ascertain the make and model number of your motherboard, it may be possible to find the motherboard manual online..
just download and install this little (free!) program - it will provide you with a wealth of information about your system..
CPUID
to download, click on the link that I have highlighted on the site's page..
if you look through the screenshots provided at the bottom of the same page, you'll soon learn how to use the program to find the necessary information..
