Windows 7: Misbehavior of sound system in window 7
21 Apr 2010   #1
jackyshaikh
window 7 HOME PREMIUM
Everyone i'm new to this forums,and this is my first post.
I have HP PAVILLION DV 2000 which was window xp before,so i upgrade to windows 7 since then when ever my system goes in sleep mode,the sound disappears.I have to reboot the system to get the sound back.
Is this normal characteristic of window 7 or any setting is required ?
other thing is while using head phone,the sound comes from speakers too.
I can't understand how to get rid of these two problems,any help would be appreciated thanks in advance.
21 Apr 2010   #2
zigzag3143
Win 8 Release candidate 8400
Quote   Quote: Originally Posted by jackyshaikh View Post
You probably just need to go to HP and download the audio driver, and install it.
Let us know if you need help
Ken
21 Apr 2010   #3
Aphelion
Windows 7 Home Premium
Yes, it is a known problem.
Microsoft had posted an -Optional- update that supposedly helped with this.
Also, look in device manager and see what kind of built-in audio system your system has.
Common types: Realtek, SIS, VIA, etc...
Ap
21 Apr 2010   #4
maceman
You just need to check out your Playback Settings. Set Default Communication Device.
Here you can find very detailed instructions with pics, if you have trouble:
How to Change the Default Playback & Recording Audio Device | Windows 7 Tutorials
Good luck
22 Apr 2010   #5
jackyshaikh
Thanks all of you guys.I tried the way you describe still no luck,problem remain same.
Audio drivers are up to date,but which kind and make don't know.
More help would be appreciated.thankyou once again to all.
22 Apr 2010   #6
Aphelion
Did you go to Microsoft update and look through the optional updates?
If you don't know what kind & make of audio driver then chances are they are not up to date.
If you look in Device Manager under sound it will tell you the Make, also... launch System Info, that will also tell you the kind of audio device you have.
Ap
24 Apr 2010   #7
jackyshaikh
yes i performed optional updates too.
I have audio driver from microsoft,which is showing upto date.
still problem ramain same,has anyone sort out this kind of case?
I need proper guidelines to solve the problem.Any help would be appreciated,thanks guys.
Similar help and support threads for2: Misbehavior of sound system in window 7
Solved Audiophile 2.1 sound system for Xonar D2X sound card. Sound & Audio
Is it possible to make secondary window sound play? Music, Pictures & Video
System Event - Changing sound makes a sound, how to mute it? Sound & Audio
No digital sound out of external sound system Sound & Audio
No sound on new window 7? Sound & Audio
window 7 upgrade no sound issue need help! Sound & Audio
