#21
okie any thing i can do now?? to fix it plz
i stil dunno what that means i just changed the connectors of the small speakers from right to left and left to right
on the sound card there are 3 wires they are like 3 colours and the sound card also have 3 holes i put them in there repective holes
nop now the one that i put in the left's hole it works its the right one i think
i mean at first the left one was working right?? now when i changed the wires and put the right one in left speakers place the right one works
now i tried again and put every single one of the speakers in the front left pannel and every speaker works but no other socket seems to be working
you mean the sound card?? i guess it dosent work with windows7 then and also when i try to connect the speakers to my built in realtek HD still the same happens
