creative sound blaster 5.1 vx
Page 3 of 4 FirstFirst 1234 LastLast
  1. Posts : 18
    windows 7
       #21
    okie any thing i can do now?? to fix it plz
  2. Posts : 878
    Connect as follows:
    Attached Thumbnails Attached Thumbnails creative sound blaster 5.1 vx-capturar.jpg
  3. Posts : 18
    windows 7
       #23
    i stil dunno what that means i just changed the connectors of the small speakers from right to left and left to right
    on the sound card there are 3 wires they are like 3 colours and the sound card also have 3 holes i put them in there repective holes
  4. Posts : 878
    That's what I was trying to tell you... So, what happened when you did changed?! Only left worked again?!
  5. Posts : 18
    windows 7
       #25
    nop now the one that i put in the left's hole it works its the right one i think
  6. Posts : 878
    I did not understand you now...
  7. Posts : 18
    windows 7
       #27
    i mean at first the left one was working right?? now when i changed the wires and put the right one in left speakers place the right one works
    now i tried again and put every single one of the speakers in the front left pannel and every speaker works but no other socket seems to be working
  8. Posts : 878
    All right! Right. Once all the speakers worked in left sound output. SoundBlaster is the issue.
  9. Posts : 18
    windows 7
       #29
    you mean the sound card?? i guess it dosent work with windows7 then and also when i try to connect the speakers to my built in realtek HD still the same happens
  10. Posts : 878
    It becomes a problem of hardware incompatibility... You changed the settings in the Realtek control panel ... with all tests done?!
