#61
Here I emded buying a pair of Sony brand cordless with the charging base. Sony MDR-RF925RK 900 MHz RF Wireless Stereo Headphone System / Audio / Headphones / Wireless - Sony - Zalmar.com
A lead cord runs to the headphone jack on the center mix speaker(5.1 surround speaker set) here. One set of Kos cordless are actually marked down quite a bit however. Amazon.com: Koss HB70 Streetstyle Cordless Infrared Headphone System: Electronics
That's a real bargain since this type of headphones can usually see much higher retail prices. Since you buy from EBay you can search there as well for good deals on the better brands. That's US Prices note.
With the corded sets I got sick and tired of not so much the cord if it had a volume adjustment on it but the cheap plastic frames that would snap on you! That's the Koss is now making the lower priced corded models where the part that holds the ear piece on simply breaks too easily.
(used Koss for high end stereo long before pc! couldn't afford quadraphonic headsets in those days however!)
But the sound was alway better except for the present set of Sony cordless in use here for the time being.
Now getting back to you on s-video there that would see both video and sound working together when selecting that input source with the tv remote. With RCA in and HDMI you likely have to make a choice if you don't hear anything while the video is clear.
I never said s-video was the best quality being composite but simply as the expression goes "a means to an end" being one solution. If you continue to use the DVI to HDMI and still hear sound when patching over from the sound card then your problem is solved that way(and obviously preferred! ).
