Sound is really quiet
  1. Posts : 122
    I have tried setting volume to max on all devices and using loudness equalization. The audio is still pretty quiet, and youtube videos are even quieter. I could of sworn it was louder at one point but I can't find anything to adjust. A flat DB modifier would be great.
  2. Posts : 28,845
    Win 8 Release candidate 8400
    first check your drivers
    Type device manager in search
    Go to the audio tab. Is your sound card listed? dows it have a yellow triangle on it? Are there any other "unknown" drivers that do have yellow triangles on them?
    Let us know
    Ken
  3. Posts : 122
    I have verified my sound drivers via system information / device manager, and they are determined as up to date. I have no unknown or drivers marked with a yellow triangle.
    Maybe I just hit a row of videos with low audibles on youtube?
    EX: YouTube - Good Size: The Pineapple Song
    BTW, I found this song trying to identify lyrics for someone, but you have to admit it's a little bit catchy.
    It's only spiking my sound meter to 50% at most.
  4. Posts : 908
    Windows 7 Home Premium
    Cute vid & song...
    The sound is fairly loud here!
    If you right click the Microsoft speaker icon in the taskbar and select playback devices you probably see speaker as the default device? Left click once on the default device then select properties... what tabs do you seeing in the window that opens/
    Do you have "Levels" and "Enhancements"
    Ap
  5. Posts : 97
    XP
    What kind of speakers you have and is it same with headphones?
  6. Posts : 122
    I do have the Levels and Enhancements options, I already made sure levels was maxed and I had already tried toggling Loudness equalization before posting.
    The speakers are built in laptop speakers, but my games, my iTunes, few other things max the volume meter out easily and are noticeably louder.
    That being said it may just be isolated to Firefox, but I have never heard of such a thing. But just in case I had tried toggling allow applications to take exclusive control.
  7. Posts : 1
    I'll join this thread because I'm having similar problems.
    - bog standard cheap Labtech headset works fine on XP on a Dell laptop.
    - same headset plugged into a new PC with Windows 7 acts as if the mic needs a preamp. I need mic volume 100% and boost +20dB to get reasonable input levels using Windows 7 Sound Recorder. I cannot make Skype work at all - need +30bD boost to pass Skype's Call test, but noise is terrible and called party can't hear me if I try a real call.
    Sound card is Realtek High Definition Audio and driver is up to date.
  8. Posts : 122
    I think it has to do with windows 7 and how it uses sound for specific applications. My Media Player Classic is pretty quiet too. Luckily I only use it to watch videos over my tv / surround so it gets amplified a bit.
  9. Posts : 1
    I resolved this annoying issue on mine!
    - Options > Internal Filters > Audio Switcher
    - Uncheck "Normalize"
    Volume got louder the second I hit Apply. Now it's more in-line with other media players on the same system playing the same video.
    [[EDIT]]
    I got to this forum by searching "media player classic too quiet"
    It looks like this thread is not about Media Player Classic specifically, but I would like to leave this post up if permitted because I'm sure others will come across it the same way I did.
  10. Posts : 1,996
    Windows 7 Home Premium 64 bit
    Are the hardware volume controls on the laptop synched with the software volume controls of the speakers? Meaning, if you turn up the hardware volume controls, does it also turn up the software volume controls. If they're not synched, adjusting the hardware volume buttons may do the trick.
