Windows 7: Front input headphone jack does not work
07 Aug 2010   #1
DrunkSupersonic
Windows 7 Home Premium
I recently run into this problem. The first time I tried to use it, it seems that the green jack for my headphones doesn't work at all. Plug in any pair and they don't even recognize it being there, as seen in Control Panel.
What might be the problem? The case has a bad jack, or the connector on the motherboard?
07 Aug 2010   #2
Dinesh
Windows® 8 Pro (64-bit)
Do you have any other headphone to try at the front jack?
07 Aug 2010   #3
Aphelion
Quote   Quote: Originally Posted by DrunkSupersonic View Post
Is it in fact... hooked up to the motherboard?
There's a header on the motherboard and a plug from the front panel assembly that fits the header. If it is plugged in, make sure everything is lined up correctly.
Ap
07 Aug 2010   #4
DrunkSupersonic
Yes it is, that's like, the first thing I did. What concerns me is that the length of the cable is a little short, and the motherboard connector with the pins is really, really far away from it, so that makes it a serious stretch. It just barely makes the distance.
EDIT: Well, those headphones have never failed me in anything until they totally died. They've worked on my iPod, my MacBook, everything else except this.
07 Aug 2010   #5
Hipster Doofus
Windows 7 Pro x64 -- PCLinuxOS KDE4 FullMonty 2011
Does it have a program something like HD Audio Deck to configure it? If so go in there & have it set. On mine I have to enable the front panel.
08 Aug 2010   #6
DrunkSupersonic
Quote   Quote: Originally Posted by Hipster Doofus View Post
Nah, it's just control panel that says it doesn't work. I THINK it acknowledges the fact that there's a plug or something there, I don't actually know, I can't get into Windows.
Headphone front jack is far too quiet
Hey Recent problem, basically I've turned up all possible volume controls I can find, tried multiple programs, multiple headphones and earphones, and the problem remains = sound is fine when it's coming out my cheap 2.1 speaker set, but when I use the headphone jack, it's really quiet. It's a...
Front panel headphone jack problems
I've seen similar posts regarding this, however none have helped so I'm starting my own one...hopefully someone can help. I upgraded from Windows XP to Windows 7 64bit. In XP, I used the front panel headphone jack for hooking up to my TV, or headset. Since I've upgraded, this headphone jack...
Front audio headphone jack reversed stereo...
I have a Gigabyte GA-P55-UD5 motherboard with on-board sound by Realtek, and my case is Thermaltake's "Element G". I connected the front panel audio cable to the designated connection on the motherboard, however, whenever I plug-in my headphones, the stereo is reversed! Meaning that the...
Front Headphone jack..
Hi guys i m new here... need some help. My front headphone jack is not working but mic is working.. Headphone works properly at rear jack. System info. System model - PI945GCM Processor Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz, 2670 Mhz, 2 Core(s), 2 Logical Processor(s)...
No Sound From Front Headphone Jack
Hi, When I first installed Windows 7 on my computer I had to manually install a sound driver. I went to the Dell site and downloaded the only audio driver for my system, Dell Precision T7500. The driver was SoundMax. The onboard sound worked, but the headphone socket one the front wasn't....
Front headphone jack does not mute rear speakers
Asus M4A78-EM motherboard using Realtek drivers from Asus site. The front headphone jack did not work until I installed the Realtek drivers from the Asus site. Actually they didnt work until I checked on Disable Front Panel Detection. That got it going but the rear speakers are still...
