Windows 7: Problem with Virtual DJ sound driver please help??
07 Aug 2010   #1
Core7
Window 7 Ultimate 32bit
I can listen to music but when I want to mix music I use Virtual DJ, but all of a sudden there is a problem can someone please help me? See screen shot
07 Aug 2010   #2
fireberd
Two suggestions. (1) Since this just happened, use the System Restore and restore back to a date when it did work properly. If that doesn't help (2) reinstall the application program.
07 Aug 2010   #3
Core7
Have done them both
No headphone sound, Realtek driver problem.
Hi all, this is my first post so I feel a bit of a fraud getting help from here, but it's driving me insane. For a while now I've had the problem of no sound from my headphones. This is the situation and what I've tried: - Sound comes from the headphones when using the standard Windows 7...
Sound Driver Problem
Well I had Windows XP ages ago and I did a a upgrade to Windows 7 Ultimate with a clean install of it and when I got it my Realtek driver was losted and my soundcard is gone so I download the driver again but still my sound didn't work , I went to a computer shop and I got fixed and it worked but ,...
Problem with sound driver
Hi, I just upgrade my pc from win xp to win 7, and it seems win 7 installed all my drivers automatically but not the sound drivers. I had problems with the sound driver back in the xp days too. My system detect my sound driver as via ac'97 enhanced audio controller all the time but the driver does...
Drivers
Sound driver problem on XP
I hope someone here can help with this. It's regarding the highlighted entry in the attached screenshot. The driver shows an error but I can't seem to fix this. None of the right-click options do anything. I can't install a new driver, I can't update it, I can't uninstall it... WTH? How...
Hardware & Devices
Problem with sound card driver
Well i have a 5.1 PCI surround cart SL-8866-SRD and we i install the driver it says "Can't find your device. Please plug in your device and press Retry to continue" what should i do? PS:I have connected the sound card, that's why i am confused.
Drivers
Sound Driver Problem with Win7
Hi every body . how are you I've got a problem with my sound card . Win7 can't see it and i was searching for the Setup + the Upgrade for it and i found nothing Name : Intel DP965LT now i'm using USB Speakers and that doesn't work with the games ( online ) it needs the real sound card...
