Windows 7: low-power audio
16 May 2009   #1
low-power audio
I have this problem, when my computer goes idle, windows will turn off my sound card..
not a bad ideal but every time the sound card comes back on it causes my speakers to make a loud annoying pop..
is there away to shut this option off and leave the sound card on all the time..
don't see the need to save power because my pc has no battery.
21 May 2009   #2
no one knows how to disable tihs?
 low-power audio problems?
Similar help and support threads for: low-power audio
Power option PCI express Link State Power Mgmt General Discussion
BSODs after possible power failure - Kernel-Power Event ID:41 BSOD Help and Support
Audio Service Is Not Running - Power Service Non-Existent Sound & Audio
Right-click Windows 7 explorer crash, 'Power' & audio service issue General Discussion
Solved Shut down computer, remove all power sources, hold down power button Hardware & Devices
