4.1 to 5.1 sound card
  1. Posts : 18
    Win7
    Hi everyone,
    well, since my 4.1 soundblaster live card the drivers doesn't work on windows 7, i wonder if is possible buy a 5.1 creative labs card (which its cheap), will my 4.1 speakers are compatible whit that card? And most important of all, does drivers of that card WORKS WHIT NO PROBLEM ON WINDOWS 7?
    Thanks.
    Filipe
  2. Posts : 6,879
    Win 7 Ultimate x64
    Assuming that ist is the old SB Live (4.1, Live and variants), have you tried this modded driver set on it,
    SB Live! series Support Pack 2.0 (04/30/2010) - Creative Labs
    As for your question about whether you 4.1 speakers will work with a 5.1 card, yes they will. Which card are you looking at?
  3. Posts : 18
    Win7
    yep, i tried those, im on xp now, works perfectly whit apropriate 4.1 creative live drivers for xp. when i install w7 whit those you recommended, or 2 speakers doesn't work or i get some noise on it, not good quality sound, ive tried so many options, even configure it but no sucess...
    yes it is my old 4.1 soundblaster live value to be more exactly.
    i will buy creative labs soundblaster live
    so, this card has good drivers whit no problem on windows 7?
    Which drivers are perfect for this card on W7?
  4. Posts : 6,879
    Win 7 Ultimate x64
    All that card is is the same as what you currently have, only difference is that it supports 5.1. It also hasn't seen a driver update since sometime in 2003, and uses the identical driver as your current card.
    If you want something with current driver support you're going to have to look something from the X-Fi series if you want to stay with Creative, or something from the likes of Asus or Auzentech.
  5. Posts : 18
    Win7
    auuf..those are still little expensive, i found creative extreme x-fi audio... i'll guess im gonna wait little more, using xp. really thanks for the help, helped me a lot.
  6. Posts : 1,086
    Windows 7 Ultimate x64.
    How much are you looking at spending on one?
  7. Posts : 18
    Win7
    Nothing more than 10 15 euros, i'm from Portugal, but why ask?
  8. Posts : 6,879
    Win 7 Ultimate x64
    Assuming the rest of your computer isn't of similar vintage as that old SB Live, have you tried the onboard sound? If the motherboard has Realtek for the onboard sound, then there is a very good chance that there are Windows 7 drivers for it (any of the others (C-Media, IDT, Soundmax) are hit and miss for support)..
  9. Posts : 128
    Windows 8 X64 M3 8102 / Windows 7 Ultimate X64
    I have 6 spare cards but im in Australia 2x Soundblaster Live! 5.1 Advanced MB 2x Soundblaster Audigy Advanced MB and a Soundblaster Audigy 2 ZS and an Soundblaster Audigy 4 Pro. I have both my current XFi Titanium and my Audigy 2 ZS in my pcs and the drivers for Audigy/Live! are one in the same
    Iforgot too add that card is the same as my other Audigy on my server and is 5.1
    Model: SB0100
    SPU Chip: EMU10K1-JFF
    1997
    Green out put is for Front
    Black is Rear
    and orange is for Digital and Center and sub
    Ill test it today on 7 and find some driver or find some 3rd party ones
    and also try downloading Vista drivers they will work also
  10. Posts : 18
    Win7
    stormy13, yes i have onboard sound, and they work on it, but i noticed the sound quality is very diferent from the original card, they don't have those effect when i play a game, or other effect when i listening music, almost its like if i have 2 speakers and sub only...i have 4 speaks for some reason, so i prefer to keep on xp or wait that x-fi cards low price.
    apollo , you mean that Soundblaster Live! 5.1 Advanced whit drivers could work on W7? which drivers exactly did you used?
