Windows 7: Help with sound!
09 Aug 2010   #1
schlampe
Help with sound!
Okay, so yesterday, my mic wasn't working but I know it's built in, so I was messing with the audio settings.
Today, I plugged in my head phones, and no sound comes out of my speakers or my headphones anymore. I went to Control Panel > Hardware and Sound > Manage Audio Devices... and now everytime I try to click on the sound, it freezes. Please help.
09 Aug 2010   #2
Jonathan_King
Windows 7 Professional x64
Welcome!
Check in Device Manager (devmgmt.msc into the start menu), in the Sound, video and game controllers section. Right-click on your card, and could you please post a screenshot of your General and Driver tabs?
A Preferred Method of Uploading/Posting Screen Shots
Also, could you please upload your msinfo32 file?
Quote   Quote: Originally Posted by JK
Enter msinfo32.exeinto the start menu, and press enter. Go to File>Save, and save a copy on your desktop. Right-click on it, and select Send to>New compressed folder. Then attach the file to your next post.
09 Aug 2010   #3
schlampe
I got it fixed, actually. Thank you, though! I had disabled something that made it not work.
09 Aug 2010   #4
Jonathan_King
Thanks for the report, glad it's working now.
What was the setting, out of curiosity?
13 Aug 2010   #5
schlampe
I had something disabled that I didn't need to have disabled, haha.
 Help with sound!
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
Sound Control panel takes 2 minutes to open; HDMI sound inconsistent
Brand new Windows 7 Home Premium (6 bit) computer. When I click on the Sound control panel item, sometimes it takes 1-2 minutes to open. But that's kind of minor (although I'd like to know how to fix it), because sometimes the HDMI sound to my HDTV works fine, and sometimes it doesn't work at all....
narrator no sound - and sound vbs file no sound
I tried this file on my other win 7 and it works fine , but I have no sound with this file . and narrator has no sound also .. system sounds and mp3 's / movies sound good ... Ideas . thanks
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
