Do I need a sound card?
  1. Posts : 362
    Windows 7 Professional 32-bit
    Hello.
    I have an onboard sound. Supplied by a Sound Max HD audio chip. Which is great but it still lingers in my head do I need one?
  2. Posts : 9,537
    Does it work ok and are you happy with it?
    There is a difference between wanting one and needing one.
    If it ain't broke don't fix it.
  3. Posts : 197
    Windows 7 Enterprise x64
    Dogz said:
    Hello.
    Also depends on what you do on your computer.. do you game, listen to music, watch movies?
    Sometimes getting a usb headset works well too.
  4. Posts : 362
    I like and I am okay with it so I think I will keep it
  5. Posts : 3,187
    The Howling Wolves said:
    ...There is a difference between wanting one and needing one...
    Second the motion.
