Auto MP3 Tagger
Page 1 of 3 123 LastLast
  1. Posts : 1,519
    El Capitan / Windows 10
    Auto MP3 Tagger
    Can anyone recommend an automatic mp3 tagger that will embed album art and get all tags from either local or remote DB? WMP12 does not always get art and is spotty on organizing the library.
  2. Posts : 166
    Windows Se7en Ultimate x64
    mp3Tag
    I use an excellent program called mp3tag. You can find it here.
    here's some info:-
    Mp3tag v2.42 - the universal Tag Editor and more ...
    Mp3tag is a powerful and yet easy-to-use tool to edit metadata (ID3, Vorbis Comments and APE) of common audio formats. It can rename files based on the tag information, replace characters or words from tags and filenames, import/export tag information, create playlists and more. The program supports online freedb database lookups for selected files, allowing you to automatically gather proper tag information for select files or CDs.
    Mp3tag supports the following audio formats:
    Main features:
    • Write ID3v1.1-, ID3v2-, APEv2-Tags and Vorbis Comments to multiple files at once
    • Full Unicode support
    • Support for embedded cover art
    • Automatically create playlists
    • Recursive subfolders support
    • Remove parts or the entire tag of multiple files
    • Rename files based on the tag information
    • Import tags from filenames
    • Format tags and filenames
    • Replace characters or words from tags and filenames
    • Regular Expressions
    • Export tag information to user-defined formats (like html, rtf, csv, xml)
    • Import tag information from online databases like freedb or Amazon (also by text-search)
    • Import tag information from local freedb databases
    • Support for ID3v2.3 (ISO-8859-1 and UTF-16) and ID3v2.4 with UTF-8
    • and much more ...
    Hope this helps
  3. Posts : 1,519
    Call me stupid but I can't seem to get it to look at a collection of songs and realize the are from the same album and correct all the mp3 tags, create the correct artist and album folders, move and rename the files and attach album art. I'd like the tool to automate that. Is there such a thing or am I using this tool incorrectly?
  4. Posts : 166
    mp3tag
    I have my songs in folders ie album folders in the music folder eg Akhon - Trouble, properties click on the folder and select the mp3tag option (if you don't have this option present, re-install and chose the option at install). mp3tag will open with all the files in the folder listed.
    Highlight all the tracks on the right of the screen (select 1 track then CTRL-A). Then select the Tag Sources option from the top menu to the top left of the screen and choose a site to tag them from (you can get more src files from the mp3tag site to give you more sites to tag from). Mp3tag will go away and search for the album details, it normally brings back a list. Select from the list and it will automatically bring back all matching details. You should then have all the tracks tagged in that folder.
    Once you get used to it it doesn't take long at all. I tagged 680 albums using it!!
    If you don't have tracks in folders and have them all jumbled up then you could try using the freedb tag source which has an option to tag from selected tracks. If you have just one folder right click on that and select mp3 then just highlight the track you want to tag using freedb.
  5. Posts : 1,519
    OK, I'm trying that now...
  6. Posts : 22,814
    W 7 64-bit Ultimate
    Hello Bellerophon.
    You should submit the program to https://www.sevenforums.com/software/...indow-7-a.html if you haven't done so yet.
    Later Ted
  7. Posts : 2
    XP
    Auto MP3 Tagger
    Hi, recently I also needed to do it. I was looking for a simple program, found a great detailed tutorial How to download MP3 album art?. In such a way I knew about mp3Tag Pro and I satisfied with it.
  8. Posts : 4,925
    Windows 7 Professional 64-bit
    WMP12 can actually tag your files in a decent way. Both by renaming the file and updating the tag. But you have to configure it to do it.
    Go to Tools, Options.
    Click on the Rip Music tab
    Click on the Filename button
    Select the details you want in the filename such as artist-album-track #-song title
    Now click on the Library tab
    Tick rename music files using rip music settings
  9. Posts : 4,925
    WMP12 can also find album art.
    If you right click on the empty cover art for an album you'l see find album info.
  10. Posts : 40
    Windows 7 Ultimate 64-Bit
    I recommend MediaMonkey, make sure you set it up correctly so it doesnt automatically amend filenames based on id3 tags, I found that out the hard way when I first installed MM :)
