Windows 7: Stereo Mix - Horrible sound, please help!
09 Sep 2016   #11
h72david
Quote   Quote: Originally Posted by Aphelion View Post
Single left click on the Stereo Mix icon then select "Properties".
Go to the Listen Tab.
Uncheck "Listen to This Device". (if it is checked) Reboot, test record.
Thanks for the answer it Worked
Sound is not in stereo
I noticed today when trying to make some settings changes to my speaker properties that my sound is in mono, not stereo. I vaguely remember making a change a while back, but whatever I changed, I don't recall. I tried everywhere i could look to see if I could determine why the speakers were mono...
How to Normalize a channle sound from a stereo sound file.
Hi to all seven forum, I have a movie audio and its left channel sound is lower then the right side. so I wanted to Increase left channel sound for equal to right side channel. I used Audacity but its "Normalizer" option didn't really works. see the image, there is clearly shown one channel sound...
Stereo mix not picking up sound
I'm on a toshiba laptop (windows 7 x64) and I have my stereo mix enabled and I want to stream some games with the ingame/music playing, but my stereo mix doesnt pick up any sound. By the way, I have a built in microphone if that matters or something. Can someone help me with this? I really need...
no stereo sound!
hey guys pls help I'm desperate.... Don't know why but I was so curious about Linux product Kubuntu and I've install it on one of my partition. Few days after I've realize that I do not like it...actually I couldn't acclimatise on it so its off now. Then my problem appeared. No stereo sound! ...
Horrible sound with latest Realtek driver
Hey there. I've looked almost everywhere and I couldn't find my exact problem. Well, technically I did but there wasn't a solution anywhere, so I decided to go ahead and ask myself. Now, I installed Windows 7 (32 bit) on my computer the other day, and I've been driver hunting since then....
No sound in stereo
Hello, I have installed Windows 7 to several PCs and this is the first time encounter a problem of this kind. The config is: AMD X2 4200+ 2GB ram MSI K8N Neo4 Platinum rev1.0 with ALC850 etc. As the title says in stereo there is no sound to the line out jack. I tried several different...
