Roughknite
- Local time
- 1:03 AM
- Messages
- 5
I'm having the exact same issue as this post, which was not solved...
http://www.sevenforums.com/sound-audio/97694-i-got-another-problem-stereo-mix-win7.html
Bascially, if I try to record through stereo mix (for podcasts or live recording over the internet) There is a horrible white noise, pulsating, echoing sound that gets louder and louder and doesn't stop. Stereo mix is set to default device, obviously, and my speakers are the default playback device, everything else is disabled.
It did not use to do this, so i'm not sure what is causing it.
I checked all the properties and its all at default settings. If I check listen to device and hit apply, I can hear the sound that keeps pulsating/echoing faster and faster until I uncheck it and it apply again. (I only checked it to see if the sound would play which it does).
I have looked all over the internet to try and solve this issue and have not gotten one step closer to solving this. Hopefully someone here can figure this out!
My goal is to record music while people watch what I am doing on my desktop. They do not have an audio feed coming to me so that is not the problem, I am the sole broadcaster.
Thank you in advanced! I eagerly await someones response.
- Windows 7
