Volume control panel dissapeared??
I installed Windows 7 RC on 2 different computers and unfortunately my windows control panel doesn't open anymore?
Anyone the same problem and what is the solution?
Cheers,
Steve
Cheers,
Steve
Can someone help me? Skype 4.0 isn't working anymore because of this problem ;(
Could you not access the control panel from first install, or did this first occur after installing any apps.?
Did you restart the computer? Did you do upgrade installs for both of them? Sometimes everything doesn't work properly when you've done an upgrade install instead of clean installs. You might try a Repair Install. It may fix certain problems, other than that, I don't know what to suggest.
Repair install didn't solve the problem. I did a clean install again and its working again. Seems the problem was Sharks Windows 7 codecs. Thanks for the tips.
I think your looking at a fresh install, and if that doesn't solve the problem, try grabbing yourself a copy of 7127..
Enzo.
Thanks, I have 7127 already.
Problem was the Shark codecs.
