Sound Card not recognized in W7
  1. Posts : 9
    XP Main
    I have an asus A8n-sli board with the Nforce4 chipset. I have creative x-fi xtreme music installed on the board and the sound works fine in XP.
    The issue is that the when I try to install the drivers it keeps telling me that there is no compatible hardware installed. In device manager it shows an audio device but no available info for it. I tried the reinstall method and moving it from one slot to the other.
    I am running 4 gb of ram, W7 64bit and do have the onboard audio turned off via the bios.
    I have tried installing drivers for the nforce4 chipset but they will not work, Is that the issue? Are there a compatible set for this, I have tried the xp64 and vista 64 drivers but with no luck.
  2. Posts : 1,379
    Sorry, don't have a solution ... but just to show you that you're not alone, I have an ASUS nForce 4 board too, installed Win7 64-bit, and like you, could not install my audio drivers because it said there was no card connected.
    I checked with the card vendor and they said (1) I had the latest drivers and (2) the drivers should work.
    I removed 64-bit, installed 32-bit (and yes, I have a 64-bit, dual-core processor), and everything worked OK. Sound card detected, drivers loaded, audo config app works fine.
    So, maybe there's a more general problem with ASUS nForce 4 boards, WIn7 64-bit, and plugin sound cards.
  3. Posts : 6,305
    A lot of hardware vendors are still creating drivers for x64 but as it's becoming more & more mainstream you should see some big leaps in development over the next few months.
    I know this doesn't solve your problem but it should give some hope that your hardware will be supported in the near future (hopefully ).
