Windows 7 Forums Search
Windows 7 - is there a hot key to control the volume...
08-20-2010   #1
Windows 7 Home Premium 64 Bit
Hello, i'm currently using internet explore 8. i was wondering if there was a keyboard hot key to lower and raise the volume on youtubes player... Feedback would be great thanks...
08-21-2010   #2
A single keystroke could not work as how would it know if you wanted the volumn up or down? At the bottom left of the You Tube Preview window is the volumn slider. Just rest your curser on the speaker icon then it's no great effort needed to slide that back and forth!
08-21-2010   #3
Windows 7, 64 bit Professional. SP1
Buy a keyboard that has the multimedia controls, such as volume up/down.
08-21-2010   #4
Win 7 Home Premium (64-bit), Win 7 Pro (32-bit)
Some keyboards have a volume control built in to them and I have seen laptops with dedicated volume controls but as a general rule there is no key that adjusts volume up/down.
 is there a hot key to control the volume... problems?
Similar Threads for: is there a hot key to control the volume...
Volume control gone. Sound & Audio
Volume Control Gaming
WMC has no volume control :eek: Media Center
Volume control! Media Center
Volume control! Sound & Audio
