Acer 1410 (No Audio Devices Are Installed)
Page 3 of 3 FirstFirst 123
  1. Posts : 7
    windows 7 64bit home
       #21
    HI
    I had the same problem and all i did was reset my bios settings to default but i frogot how to reset it.
    So Sorry
    Boris
  2. Posts : 908
    Windows 7 Home Premium
       #22
    Lolik42 said:
    HI
    So Sorry
    Boris
    There will be a jumper on the motherboard that resets the BIOS, or... you can remove the small pancake battery out for a few minutes.
    pancenter-
  3. Posts : 13
    Windows 7 Ultimate
       #23
    Thanks for the tips guys, I'll try it out over the next day or so, once I can get to a place where I can somewhat safely take my laptop apart.
    Aphelion - Do you have any sense how I would identify which jumper to try?
    Also (general question) - Does anyone out there have any way to identify if this is actually a hardware issue, as in a broken sound card?
  4. Posts : 908
       #24
    No, don't take the laptop apart, doubt if there's a jumper available.
    See if the laptop's CMOS battery is easily accessible, then remove it for a few minutes.
    If you want to check hardware you could back up your data and re-install the OS.
    Ap
  5. Posts : 13
    Windows 7 Ultimate
       #25
    No Luck
    Aphelion,
    I had a laptop tech try to remove the CMOS battery, but the problem still persists. Aside from reinstalling the OS, is there any other way to diagnose whether or not the problem is rooted in the hardware?
