No sound - This device cannot start. (Code 10)
anciie
9:02 PM
Hello!
Since I got Win7 my sound isn't working anymore.
When I go to sound it says "no audio devices are installed". And when I go to the device manager it says "this device cannot start (code 10)"
It says that the drivers are up to date when I search for them, but I still tried to install various audio drivers. But it's still not working.
High definition audio device:
Device tyep: Sound, video and game controllers
Manufacturer: Microsoft
Location: Location 2 (Internal High Definition Audio Bus)
Help, please?
EDIT: Oh, I almost forgot.
Motherboard Name: Gigabyte GA-8GPNXP Duo (2 PCI, 3 PCI-E x1, 1 PCI-E x16, 4 DDR DIMM, 2 DDR2 DIMM, Audio, Dual Gigabit LAN, IEEE-1394)
Windows 7 Ultimate Media Center Edition 32bit
anciie, welcome to the forum.
Most the problem stems from your motherboard having an unsupported chipset (Intel 915), and an equally unspported audio chipset (C-Media 9880),
http://tw2005.giga-byte.com/MotherBoard/Products/Products_Spec_GA-8GPNXP Duo.htm
For the chipset it should be OK with whatever native driver Windows installed for it, for the audio about the best you can do is to try the last XP driver for it,
http://tw2005.giga-byte.com/Motherboard/Support/Driver/Driver_GA-8GPNXP Duo.htm
It may take installing using compatibility mode (says for Vista drivers, but the same applies to XP drivers),
http://www.sevenforums.com/tutorials/98073-drivers-install-vista-drivers-windows-7-a.html
Me
Win 7 Ultimate x64
FX-8350 @ 4.6 GHz so far
Asus M5A97 EVO
Sapphire R9 270x Dual-X
Acer S232HL Abid
120 GB OCZ Vertex 3
500 GB Seagate 7200.12
Antec Earthwatts 650W Green
Antec Three Hundred
Cooler Master 212 EVO
Logitech G510
Logitech G500s
Hello!
The DL link you gave me wasn't working, but I tried DL-ing it from somewhere else and it's working.
Thank you so so so much! (:
