Recording: no Audio devices are installed.
  1. Posts : 7
    windows 7 64bit home
    So i got a new headset and i found out that the sound works but not the mic.
    It works on other computers but not on my because it doesnt show up grey, it doesnt show up at all even thought i did check the show dissabled or disconnected devices. I tried to instal a new upgrade for my sound but the windows 7 said that i have the new upgrade.
    If someone could help me it would be awsome
    Thx
    Boris
    Sound card : High Definition Audio Device
    Are you using the Dell supplied sound drivers? I do a lot of support on the Dell users forum and we have found that not using the Dell sound drivers can cause problems in some systems.
    Dell does not support Win 7 (no Win 7 drivers) for the XPS420 however they do support Vista and the Vista drivers should work without problems. The Vista SigmaTel driver is HERE If you have anything other than the Dell SigmaTel driver, suggest you uninstall whatever you have and install the Dell SigmaTel driver.
    FYI the Dell users forum can be accessed http://en.community.dell.com/ You may want to check out the support forums.
  3. Posts : 7
    yes that did it,
    thx a lot dude
