Windows 7: Sound Mixer Issues
28 Aug 2010   #1
ilKhan Ozy
Windows 7 Home Premium 64-Bit
Sound Mixer Issues
Not so much an issue, as a general question.
Is there a mod or update that will allow you to select which audio output device a program will use? I know some programs allow you the prioritize outputs, similar to Skype, but I am an avid fan of ... "home videos" and it would be rather embarrassing if I was watching one and it began to play through my main speakers. That might attract undue attention to my ... "home videos" if you follow.
I have tried going into the control panel and forcing the headset as the default device, but Windows is all high and mighty about using the built in speakers for some reason.
29 Aug 2010   #2
fireberd
Normally, if you plug in a headset to the front panel headset jack (on a desktop) or the headset jack on a Laptop it mutes the PC's speakers and you get "private" audio.
I don't know of anything that will allow outputting different audio on different devices. You only have one audio "card" (chip) and it's taking whatever input it is getting and converting it to audio and sending it to the speakers or headset depending on what is plugged in or selected.
When you are viewing "private" videos only have that audio playing back and control where it's heard.
29 Aug 2010   #3
ilKhan Ozy
Theirin lies my issue. I have the speakers set to mutes, and my headphones set to emit sound, but Win7 defaults media player to the System Speakers. There is no way to jump it over to the headset sound board. I'll see if I can get som screens up this evening to show you what I mean.
29 Aug 2010   #4
fireberd
If your hardware (and sound drivers) are working correctly when you plug in a headphone to the front panel headphone jack it will automatically mute the speakers and any audio, whether from WMP or any other application that is playing audio will go to the plugged in headset. Herein lies the problem, your sound card (or integrated audio chip) is not muting the speakers when you plug the headset in.
29 Aug 2010   #5
ilKhan Ozy
Not quite. There is no issue with the system speakers being muted or unmuted. I can do that manually. It is simply an issue of the sound card or windows internal prioritization failing to produce the sound signal at both the 3.5 mm jack and through the system speakers.
I have a feeling that this is part of the Windows 7 enhancement features or whatever. I feel this way because it will list the Player as being sent out on the Speaker channel, whereas it will so far only direct Skype or what have you to the 3.5 jack.
Check my attached images, they show you what I am talking about. I think the key issue lies in the fact that the Windows Sound Mixer chooses for you, instead of letting you choose where to send the sound output signal.
29 Aug 2010   #6
fireberd
This is the first I've seen or heard of this. I don't have that on my SoundBlaster sound card and no one on the Dell forum, with IDT has brought this up. I can't help you with this. Maybe one of the others here can help.
 Sound Mixer Issues
Unknown Sound Volume Mixer
Svchost.exe virus I've been on 4chan /g/ and they sent me here. I'm not to sure on what this is, the application I've narrowed it down to is svchost.exe. This thing plays sounds, songs, advertisements; kinda like someone is rotating through an AM radio station. I've tried my best to remove...
System Security
Sound Mixer settings
Hi folk's, required a little help here see the attached screen shot. I want to change all the other volume on 100% except for the master voume which i want to keep according to my need. So how can i do it ? please do reply thanks to all in advance
Stuttering sound + Sound mixer "System Settings" flashing in and out
This is a weird issue I'm having. I did a restart and when I came back BF3 wasnt playing any sounds, which is weird because it was just working. I went to make sure it wasnt muted in the mixer, and I see the weirdest thing. The application "System Sound" is disapearing in and out very...
windows 7 sound mixer
I have windows 7 OS on my laptop. The default audio output is the inbuilt speakers. I also have a wireless headphones set. When I connect to the headphones via bluetooth it is recognised and I can change its volume from the volume mixer. But I am not able to control which programs play on which...
Volume Mixer lost IE sound...
So when you click the sound icon in the tray and then Mixer usually IE, Windows Media Player, and any other application that uses sound shows up, but now IE is missing there... does anyone know what could have caused this?
Issues with Windows' Volume Mixer
Hey guys! I'm having some small problems with Windows Sound Mixer! It happens when I'm playing Left 4 Dead. Every time that I win a level, the Sound Mixer lowers the volume of the game. If I'm listening to music in WMP or WMC, it pauses the music and lowers its volume too. One weird thing, is...
