Ok here is my problem last week I bought this aforementioned laptop. I blew away the 64bit Windows 7 Home Edition it had on it and installed the 32bit Windows 7 Ultimate.
The problem I am having is that the audio that comes through the speakers sucks with certain things like Windows Media Player when I am watching dvds or downloading movies or Tv shows. When I do this you can barely hear the audio. On the other hand if I plug in my earphones the audio is perfect and I get crystal clear HD quality audio.
The codecs I am currently using are the Windows 7 Shark 007 codecs.
Problem I am running into now is finding suitable drivers. When I go to Toshiba to download drivers:
Model Content Page
all that I get is drivers for a 64bit system when I actually need their 32 bit versions.
With that said can some help me find the appropriate and latest 32 bit audio drivers for this system. Also if anyone has anymore ideas as to what might be wrong here I am all ears and would appreciate your input.
With that said thanks in advance for your help.
