Windows 7: Fatality Series Front Panel Problem
02 Sep 2010   #1
jambokaos87
Hi guys!
Just had my nightmare barebones bundle shipped back to me after a repair to find there is seemingly no power to the I/O front panel for my Fatality Series Sound Card as the lights don't power up. This was working seemingly fine prior to the transport. The headphone jack works and the system recognises that headphones are connected but the volume knob does not function from the front panel.
Took the case open and quadruple checked that the cables were properly seated and in the correct way at both the sound card end and the front panel end and still no joy. I then again removed both ends and firmly reseated them, making sure they were not shimmyed in or bent and still no joy.
Could this be driver related?
Or perhaps even connected with the BSOD problem i experienced before?(http://www.sevenforums.com/crashes-d...ndom-bsod.html)
RMA'ing this could be an issue as me being the extremely clever individual threw away the packaging (yes I am a massive fool)
02 Sep 2010   #2
fireberd
I have an Xfi with the disc drive slot front I/O panel. Other than possibly the basic Xfi drivers the only other thing is the interconnecting cables. If the cables are connected correctly, and I'd reseat both cables at both ends again, then it has to be a hardware problem and most likely in the card.
Using both front panel audio and back panel: solutions
This possibly should go in the hardware forum since it involves the motherboard as well but being a sound issue I assume here would be better. I have an Asus Xonar DG sound card on an Asus P7P55D-E LX motherboard (and AMD Radeon HD 7800 Series video card) running on Windows 7 Home Premium...
How to disable read audio panel and make the front panel primary?
Hello. I am having a not so common issue of a problematic REAR audio panel jack. The microphone pin got stuck and broken into the rear/back microphone jack and now the OS/driver thinks there is a microphone in the back panel but I just want to be able to make the microphone work on the front panel...
Front mic panel problem, says its unplugged
Ok im at wits end! Im pretty sure i got this to work before. But i forgot how to do it. My front mic panel doesnt work ive spent hours trying to find the solution but failed :cry: The front panel used to work before so im sure it shouldnt be a hardware issue. About six months ago i was tweeking...
Hardware & Devices
Creative X-Fi Titanium Fatality Championship Series Crackle/static/pop
Hi guys...new to this windows 7 forum When i play songs on my itunes using my Creative X-Fi Titanium Fatality sound card... i keep hearing Crackle/static/popping sounds whenever i run pgrms on my comp basically what i faced is almost somewhat similar to this member's problem...
Problem - Noise front panel
Hi, I have a Asus P8Z68-V PRO with an Intel i5 2500Kand have a very annoying trouble. The front panel of my tower (Nox Blaze) when i connect my headphones to audio out make a very low profile noise, it seems like electromagnetic impulses ... When the CPU is used at 100% the noise...
Front panel..
Please Help me! I can't make play back and front :( Ihave plugged both and fron and back panel but still have a problem... And my Realtek HD audio manenger looks different... How i have make that with this? there is no Folder option... What should i do on that? :eek: EDITED: Oh ya then i...
