Need urgent help with audio
  1. Posts : 5
    Windows 7 Professional x32 bit
    Hello guys.
    I have laptop HP pavilion Dv6000, it has Conexant High Definition Audio. The sound was working while ago, then i had a problem with my charger the wire broke so i had to wait month before i got my charger. Sound worked when i got my new charger but then suddenly it stopped working. I restored my computer to previous state and It started working again. But then after 1 hour or so it stops working.
    The volume controller on right bottom has a cross sign and when i click on it to troubleshoot it says driver changes might not be detected. When I go to device manager there is not content for sound, video and controllers. when i try to install the driver it says media device is not found for this driver.
    Please help me I am tired of this, I have windows 7 professional.
    thank you for your time and help
  2. Posts : 1,797
    Windows 7 Ulti. x64
    Welcome to SevenForums nizankhan
    When you look in device manager are there any entry's with the yellow ? in it. If so try to update that driver by right click and click properties.
  3. Posts : 5
    Thank you for reply
    there was on device like that processor i installed it, sonud came back. But now its gone again, and there are no yellow signs or anything and plus my dvd drive is gone to. plz help : (
  4. Posts : 1,797
    Windows 7 Ulti. x64
    Have you ran a virus scan to see if this may be a virus problem? Also you can run malware scan. I like the malewarebytes found at this link.
    Malwarebytes' Anti-Malware: Malwarebytes
  5. Posts : 5
    had 6 files infected, I removed the torjan but still no luck, no sound
    thank you for helping me
  6. Posts : 1,797
    Windows 7 Ulti. x64
    So did you try reloading your drivers now that you have cleaned some bad guys out?
  7. Posts : 8
    Win 7 Home Premium 32 Bit
    This seems to be a problem with the Conexant drivers that after a while they just go BYE BYE I have some friends with Laptops and some desktops that use the same driver and it is constantly trying to reinstall after a restart or cold start
  8. Posts : 5
    Oh man same thing again,MEDIA DEVICE CANT BE FOUND FOR THIS DRIVER. any more ideas?
    thank you very much for helping.
    I do not know what happened it was working perfectly fine before I stopped using my laptop for month : (
  9. Posts : 14,606
    Ok not sure i can help with soundcard issue but try this microsoft fix for dvd
    Your CD or DVD drive cannot read or write media
    on my old pc i used to get a problem after i booted ,i would get a cross on the volume speaker icon bottom right also. it drove me nuts trying to sort it out but the thing i did to fix it was to left click the icon then turn the volume up or down and the x would dissapear. i still dont know why it had an issue but that was a fix , i dont suppose this will work in your case but its worth a shot!. good luck
  10. Posts : 5
    I got the sound working. But again after few hours, drivers gone. I cant even install it, I disable my display driver and uninstall my nvideo chipset drivers then i tried to install my sound and it worked. Then later i installed my nvideo drivers and after few hours sound was gone. So I again disabled and uninstall the nvideo drivers but now i cant install it. U know how you go to Have disk option and select the file and it pops up the driver and youclick neext, i do that but no drivers pops up. man this is so annoying i feel like smashing my laptop!!!!!!!!
