SRS Volume Problem on Realtek HD
  1. Posts : 4
    Windows 7 Ultimate 32 bit
    Hello
    I have windows 7 ultimate 32 bit and i have installed SRS HD Audio Lab on my reltek but there is a sound problem
    The volume comes low.......
    plz help
    Attached Thumbnails Attached Thumbnails SRS Volume Problem on Realtek HD-untitled.png
  2. Posts : 4
    plz need help quick anyone
  3. Posts : 1
    Try this, switch your default playback device to your Realtek sound card. Then crank the master volume all the way up to 100%. Then set the default playback device back to SRS HD Audio Lab. This should fix the audio issue.
  4. Posts : 4
    The Same Problem
    Actually Its a Laptop And Its Sound Card Is A Stereo So Mebe thats a problem that my sound card is low quality one but on the stereo sound of my realtek the sound is great up to 100%.And The SRS is low till 30% or 40%
    And i Have 5.1 surround speakers and its working to stereo mode not original 5.1
    SRS is Good And Some how Tell Me the way to Get That System Volume to 100%...
    I will be very thankfull to you for this act of kindness............
  5. Posts : 4
    and also i got a prob that i cant open the SRS controll panel Can you Give me the Activation Key plzzz
    And when i close the cotroll panel the voice suddenlly get full but not good
